i think i know whats wrong BUT....is it the carborator?
Old 07-17-2013, 01:30 AM   #11
Default Re: i think i know whats wrong BUT....is it the carborator?
Originally Posted by phillycincykid View Post
ok now that i learned something new today lets start here......my prop is a p19. like i said i was @4500 rpms and reaching 30 mph on a alpha 1 outdrive. 5.7 v 8. i have a stainless steel prop i have never used that is a p23. never used it cause i mostly go on the river and was told that they are not forgiving if you hit something....when i conducted this experiment i was on the lake. ill have to throw the stainless on at the lake see what happens b/f i dive into the timing issue.
Hmmm... the 19" pitch should be almost perfect for your boat. The 23" pitch will likely give you horrible hole shot and bring down your rpms by 700-800 which means you are well below the recommended range (4400-4800) for your boat which will have your motor lugging. IF its the 19" prop then i'm wondering if its really a 19" as its possible the pitch has been altered with any repairs done to it. Try the 23 though just for comparison but i suspect it will be too high. As for the 'forgiving' part, the hub in a SS prop is designed just like a hub in an aluminum prop. Both should let go on impact to reduce any possibility of damage to a gear gase. Repairing a SS prop just costs more money.
  • Old 07-18-2013, 12:56 AM   #12
    phillycincykid's Avatar
    phillycincykid is currently offline
    My Year: 1990
    My Model: xlc 2150
    My Engine: 5.7 l mercruiser
    Send phillycincykid:
    a buddy of mine has a 21 pitch prop im gonna try this weekend b/f i go up to the 23 stainless prop. we'll see what happens. also going to try to GPS my speed just to make sure my speedometer is properly working. fixed it last year but could be off again
    Old 07-18-2013, 12:57 AM   #13
    crashcourse101's Avatar
    crashcourse101 is currently offline
    My Model: Barchetta
    My Engine: 4.3 alpha1 gen2
    Gallery Images: 9
    Send crashcourse101:
    What carb? I am having a similar issue with mine and I may have a fix.
    Old 07-18-2013, 02:00 AM   #14
    My Year: 1990
    My Model: xlc 2150
    4 barrel. i believe its a holley
    Old 07-18-2013, 06:07 PM   #15
    My Model: Barchetta
    Gallery Images: 9
    Holleys are fairly easy to rebuild just make sure to get the right kit if you go that route.
    I checked the issue or idea I had to what you have and its not the same. How is the hull ? how clean is it? I was getting 3700 wot rpm and 27 mph when I first got my boat and it would not do a tick more. There was so much scum and crap on the bottom that would not let me slide.
    I now can run 4500 with a 19 at 36-37 on the gps but that is it. I have completely went through ignition system minus the ignition module and have rebuilt my carb and I am having the same issue still. Can you free rev the motor past 4500? My motor will not it starts to pop and sound loaded up.
    I would think it would load up a tad or smell rich but it sputters and pops past 4200 so I think I am overfueling at wot and am planning to go down a half a jet size to see if it helps me.
    Old 07-19-2013, 12:15 AM   #16
    My Year: 1990
    My Model: xlc 2150
    i have not tried to free rev the engine past 4500 rpms. that is something i will try. As far as scum on the hull.....Eric doesnt allow that too happen! in fact just the opposite i spent 3 days before we took her out the first time wet sanding and de oxing the chalk away buffing and polishing. i need to rebuild my carb regardless if this is my problem b/c i never had it rebuilt in the 3 years i owned it. i will try a few things this weekend and see what happens. im curious. will let everyone know what happens.
    crashcourse101 likes this.
    Old 10-03-2013, 01:05 AM   #17
    finleydj is currently offline
    My Model: 220 talari
    My Engine: 5.7
    Send finleydj:
    Any updates? Im interested in knowing!
    Old 10-03-2013, 01:46 AM   #18
    My Year: 1990
    My Model: xlc 2150
    put a 21 pitch prop on helped alot but broke the cavitation plate later that day! since i have to put a new lower unit on , ill know for sure next year!
    Mariah 1990 XLC 2150 5.7 V8 about halfway rebuilt.
    Old 03-03-2015, 03:52 AM   #19
    My Engine: 5.7
    Send finleydj:
    Any update for 2014?
    Want to add sub under Drivers seat, but don't want compass to read wrong! scubydo Original Mariah Talk 0 10-07-2010 02:21 AM
    Wrong Prop? KStone803 Prop Talk 0 07-29-2010 12:09 AM
    whats in a name firebug14 Original Mariah Talk 3 05-22-2009 02:03 PM
    so whats new! ?!?!? 180diablo Chit Chat/Off-Topic 5 11-23-2007 12:24 PM
    There are 380 users
