Flushing Mercruiser
Old 02-07-2015, 02:17 PM   #1
Glen is currently offline
My Model: Don't know just bought
My Engine: 4.3 Mercruiser
Send Glen:
Question Flushing Mercruiser
I am new to I/O's and have a 4.3 Mercruiser with an engine mounted raw water pump. To flush the engine with water while warming the engine and to later add antifreeze to the system, do you do this via muffs on the outdrive or connect directly to the water pump for one or both procedures? I am assuming that to flush with water from a pressurized hose, you would use the muffs and to use a gravity feed system for the antifreeze you would connect directly to the pump but would like to hear some comments from those more experienced at doing this. Thanks
  • Old 02-07-2015, 02:34 PM   #2
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Default Re: Flushing Mercruiser
    Muffs all the way.
    Otherwise you'll trash the impeller in the leg.
    Old 02-07-2015, 07:27 PM   #3
    Send Glen:
    Andy, I understood that there would be no impeller pump in the outdrive if there was a motor mounted raw water pump. Am I wrong?
    Old 02-08-2015, 11:07 AM   #4
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    What leg?
    If it's an Alpha 1 then there's an impeller in the leg and a circulation pump on the front pulley of the motor.
    Old 02-08-2015, 01:44 PM   #5
    Send Glen:
    I acquired this boat recently after a relative passed away, however, it is in storage and bubble packed at a marina up here in Canada so I haven't actually seen it. I have been told that there is definitely a raw water pump mounted on the engine (in addition to the engine circulating pump) so I believe the outdrive is a Bravo.
    Old 02-11-2015, 06:18 PM   #6
    Danish Mariah SX 18 Owner is currently offline
    My Year: 2006
    My Model: SX18
    My Engine: 3.0 - 135 HK
    Send Danish Mariah SX 18 Owner:
    Here is my setup for winterizing my mercruiser 3.0 L
    works without any leakage of anti freeze.
    Andy b and Glen like this.
    Old 02-11-2015, 08:38 PM   #7
    Send Glen:
    Great Pics. I have saved them to my Mariah file and will definitely refer to them for future flushings. Thanks very much.
    Old 02-12-2015, 03:07 PM   #8
    My Year: 2006
    My Model: SX18
    You are welcome,
    Plase note!, that its important that there is enugh flow thru the hose, and there is a second air vent hole in the antifreeze container, otherwise you will ruin the impeller!
    i also have the drawing with measurements, for the cardboard plate, used under the haul on the picture
    i wlll post them later here,
    Glen likes this.
    New 4.5L V6 Mercruiser Andy b Mercury MerCruiser 8 11-25-2014 01:55 PM
    Mercruiser 5.7L Q's dabates Original Mariah Talk 4 07-11-2011 03:05 PM
    flushing the Engine embasun Original Mariah Talk 7 01-19-2010 05:15 PM
    Engine flushing A320 General Maintenance 4 04-24-2009 09:25 PM
    5.7 L Mercruiser 300sflyer Mercury MerCruiser 8 07-29-2008 04:42 PM
    There are 348 users
