Starter?
Old 05-27-2013, 04:48 AM   #1
soloyosh is currently offline
My Model: Z210 Shabah
My Engine: Bravo IIi
Send soloyosh:
Default Starter?
I took my new to me z210 out on Saturday. It started fine in the slip and after running for about 30 minutes we stopped to setup a tube. I went to start it again and nothing. No turning of the starter. I dropped anchor and proceeded to open the engine cover. When turning the key to start there was a click near the top of the engine, but nothing at the starter. I am assuming its like any other Chevy starter (Mercruiser 5.7L) and there's a solenoid on it. I hit it with a rock from shore thinking the solenoid was stuck to no avail. The solenoid and starter were very hot.
We got towed back to the marina after enjoying some swing and lunch.
My working theory is that the solenoid stuck when starting that morning and for the whole cruise the engine was driving the starter, burning it out. Thoughts?
Also, any tips on removing the starter? The previous owner has done it before and is going to lend a hand but I was wondering if you guys knew any tricks that would be helpful.
Cheers
Brett
  • Old 05-27-2013, 11:58 AM   #2
    Default Re: Starter?
    I dont know about any tricks (other than getting someone else to do it for free) to removing & replacing a starter but if you want a troubleshooting guide to go thru before you remove/replace the unit click here.
    jiduncan likes this.
    Old 05-27-2013, 01:22 PM   #3
    Check and make sure the flywheel isn't chewed up if you suspect it was stuck on for any length of time.
    Bummer
    Old 05-28-2013, 03:30 AM   #4
    Send soloyosh:
    Traced it back: the solenoid on starter was bad. Unfortunately I couldn't find anyone local that just sold the solenoid, so I picked up a whole new starter from West Marine in town.
    It took me a bit but I got it installed and took the family out this afternoon for some tubing.
    When we got back, I did restart it just to make sure everything was good.
    Back in business.
    Thank you for the help.
    Cheers
    Brett
    Old 05-28-2013, 03:32 AM   #5
    Send soloyosh:
    Bummer
    Ring gear teeth looked great.
    Thank you.
    Cheers
    Brett
    Old 05-28-2013, 04:14 AM   #6
    Awesome Brett!
    Starter issue usmcitalion Mercury MerCruiser 2 11-23-2011 09:08 PM
    starter rwasson89 Original Mariah Talk 5 06-13-2011 03:51 PM
    Starter huntnfish Mercury MerCruiser 6 07-25-2010 04:41 PM
    Bad starter? Dogloop Mercury MerCruiser 9 07-03-2009 09:20 PM
    Help with starter issues MariahShabah3.0 Original Mariah Talk 10 09-10-2007 06:04 PM
    There are 335 users
