Starting issue
Old 04-14-2013, 12:47 PM   #1
Twostroke is currently offline
My Model: shabah
Send Twostroke:
Default Starting issue
My 4.3 l has this starting issue, on the first start up it takes forever to get going sometimes it fires right up but then stalls. I have to remove the air breather and play with the carb while someone cranks it over. After it starts it runs perfect and starts perfect for the rest of the day even if it sits for a few hours. Any thoughts?
  • Old 04-14-2013, 01:02 PM   #2
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Default Re: Starting issue
    Sounds like fuel, are you pumping the throttle 3 or 4 times before you turn it over?
    if it's been stood a while turn the ignition on and of a couple of times to let the fuel pump lift some gas from the tank. pump the throttle 3 or 4 times then set the lever at about 1/4 open and crank....
    if that doesn't work then you may need to service the carb, but like you say once it's going it's fine
    Old 04-14-2013, 01:09 PM   #3
    My Model: shabah
    Send Twostroke:
    Yep I have done that as well. Has to be my choke not closing at the right time or a week fuel pump. Fuel pump so quite I can't even hear it
    jiduncan likes this.
    Old 04-14-2013, 01:17 PM   #4
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    Check and make sure the accelerator pump is squirting fuel too. Mine has the same prob and that's what it is. I almost have to shoot some carb cleaner in it if its sat for awhile. A carb rebuild is on my short list for it.
    Old 04-14-2013, 01:18 PM   #5
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    Well if you have a suspect pump I’d change it anyway. Don’t want it failing out on the water.
    See if it makes any difference and go from there.
    Does it bog down if you run a WOT for a period of time?
    i had the slightest nick in mine on my 3.0L and it was a bugger to start cold
    Old 04-14-2013, 01:19 PM   #6
    My Model: shabah
    Send Twostroke:
    nope runs 100 % after i get it going for the first time of the day
    Old 04-14-2013, 01:56 PM   #7
    Throw in a anti siphon valve at the fuel tank. Should be a screw in fitting right at the tank. It might be stuck in the open position , or sticking anyway causing the fuel to return to the tank.
    Just a thought
    Old 05-15-2013, 01:45 AM   #8
    My Model: shabah
    Send Twostroke:
    Got my starting issue fixed it was the Choke not working proper and would almost stay closed causing engine to flood, after setting all seems 100%
    Old 05-15-2013, 01:47 AM   #9
    Just in time to cut it loose this season!
    Nice job
    Old 05-20-2013, 03:31 PM   #10
    Mark from Long Lake is currently offline
    My Model: 1997 Shabah 186, Mercury 4.3
    Send Mark from Long Lake:
    I just posted a new thread related to the fuel pump sending unit. My fuel pump works, but it's not getting the signal from the sending unit. Does anyone have experience with that (put a new fuel pump in last year).
    Mark
    starting Brad97 Original Mariah Talk 5 01-01-2013 05:05 PM
    starting issue 454mag Mercury MerCruiser 2 09-25-2012 01:16 PM
    starting issue Stutterin_nate General Maintenance 7 05-28-2012 02:14 PM
    Hard starting 5.7L My 210 Talari Original Mariah Talk 9 09-29-2011 03:21 AM
    Not always starting Snowaterdude Original Mariah Talk 1 09-20-2009 03:31 AM
    There are 254 users
