Suddenly my Boat won't start & trim doesn't work
Old 12-28-2012, 07:09 PM   #11
guyjusthere is currently offline
My Engine: 4.3L Merc
Send guyjusthere:
Default Re: Suddenly my Boat won't start & trim doesn't work
tested starter. it's focked. ordered a merc version. womp womp
  • Old 12-28-2012, 07:10 PM   #12
    Send guyjusthere:
    Now i need to figure out why my trim switch does nothing
    Old 12-29-2012, 12:41 AM   #13
    csterner's Avatar
    csterner is currently offline
    My Model: Z275ST Shabah
    My Engine: 6.2L Bravo III
    Gallery Images: 9
    Send csterner:
    I would always check your grounds first. Make sure they are all shiny and well contacted. Then check your switch. Are you getting voltage out of the switch when activated? If not, take the switch apart and clean the contacts if it can be taken apart. Not sure of your setup, but here is what I went thru.
    Check grounds
    Clean switch contacts
    Check trim solenoids. They should be next to your trim reservoir. Make sure all contacts and wire terminals are cleaned and shiny.
    If you are getting voltage out of the switch, then try "jumping" your solenoids. I have 3 of them. Not sure how many you will have. If voltage gets to the solenoid and nothing happens when you jump it, then the solenoid is bad.
    If solenoid is working, then check for a reset switch on the trim motor.
    That's all I can think of right now....
    2001 Shabah Z275 ST
    6.2L Merc with Bravo III
    Old 12-29-2012, 02:54 AM   #14
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    Poor memory is telling me power for the trim pump comes off the starter solenoid? Battery side so hot all the time?
    Old 12-30-2012, 01:40 AM   #15
    Did you look at the "How To..." for the trim system? Its pretty easy to follow.
    Old 01-06-2013, 05:50 PM   #16
    Send guyjusthere:
    If anyone reads this:
    The problem was my starter. New starter fixed issue.
    I believe my old starter was seized up. It was drawing a lot of power but had no go. Either that or the solenoid wasn't delivering full power... W/e fixed.
    My trim was a bad ground. Just cleaned some terminals and boom!
    Old 01-06-2013, 05:56 PM   #17
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    Glad you got her fixed!
    2001 Shabah Z275 ST
    Trim Motor Doesn't Work - Clicks on Down but Nothing on Up Dredd Mercury MerCruiser 5 08-04-2021 06:08 PM
    Trim does not work claycustom Introductions 5 07-14-2012 12:23 AM
    Mariah Shabah 180 won't turn over suddenly? VF143_vet Mercury MerCruiser 5 07-04-2010 06:32 PM
    No trim, bilge blower, hard to start TJShabah Original Mariah Talk 3 08-30-2009 01:03 PM
    Boat won't start kgoo Original Mariah Talk 21 08-07-2009 06:25 PM
    There are 286 users
