-   -   Suddenly my Boat won't start & trim doesn't work (http://www.mariahownersclub.com/forum/mercury-mercruiser/7665-suddenly-my-boat-wont-start-trim-doesnt-work.html)
guyjusthere 12-24-2012 04:24 PM
I tried checking fuses and ground and got a new battery. Still nada. I tried bypassing the starter. Still only getting a click. Trim switches do nothing.
2000 Mariah v6 mer cruiser
Andy b 12-24-2012 05:07 PM
Re: Suddenly my Boat won't start & trim doesn't work
start with the simple stuff first, kill cord/battery isolator. then work from there
mikeyt 12-24-2012 06:08 PM
Have a look thru our guide to Troubleshooting your Starting system....
guyjusthere 12-27-2012 08:53 PM
done all of this.
I hear a click. Sometimes the starter moves a small amount.
If I place a jumper to the braided "ground" wire going to the starter, the engine turns a tiny bit on every key turn; But the wire gets very hot.
When I place a test light onto the braided ground wire; the light turns on. When i turn key. I hear a click and the light goes out until i return key to off position.
Every attempt to jump the starter solenoid fails. I don't even hear a click. just a weird winding noise...
ColoradoDiablo 12-27-2012 09:02 PM
Need to verify you have 12v at the starter main cable , could be just a bad cable or connection , but it sounds as though the starter drive is giving you problems. It's drawing a butt load of current it sounds like.
I'd just pull it and have it tested. Then you would be able to move to another area if it is OK.
JMO
guyjusthere 12-27-2012 09:09 PM
Thanks for the response!
How do you pull the starter? Is it two long bolts in the back?
4.3 mercruiser carb
ColoradoDiablo 12-27-2012 10:47 PM
Yes sir ,
Kinda a pain to get at sometimes , but very doable.
Pull the mounting bolts and then undo the wiring. Pretty straight forward.
See attachment #2 in mikeys post for the wiring at the starter.
Mark.S 12-27-2012 11:25 PM
you did try turning the motor over by hand ?to make sure the motor is not seized up
guyjusthere 12-28-2012 06:01 AM
how do you turn an inboard over by hand?
I am pretty sure it's not seized. i was runner her fine last weekend. Starter has been showing signs for a few weeks. I just thought it was the battery.
husker_fan 12-28-2012 09:59 AM
Should be able to use a 5/8 deep socket on the crankshaft pulley.
