where is the oil sender unit located?
Old 09-10-2012, 09:01 PM   #1
csterner's Avatar
csterner is currently offline
My Model: Z275ST Shabah
My Engine: 6.2L Bravo III
Gallery Images: 9
Send csterner:
Default where is the oil sender unit located?
Hey guys! I have a 01 Z275 with a Merc 6.2L. I believe that my oil sender unit is bad. Last Sat I looked all over the engine block and could not locate it. I talked to someone today and they said it is located under the engine block next to the oil pan. Is this correct? If so, I believe I will have to pull the engine out of the boat to get to it... I might have to tie myself off to a tree and hang upside down to get my head any further under there!
2001 Shabah Z275 ST
6.2L Merc with Bravo III
  • Old 09-10-2012, 10:42 PM   #2
    Default Re: where is the oil sender unit located?
    Chris looks like both the sensor for the alarm and the sender for the gauge are right above the oil filter on the block. If you have a remote filter it is in the same place above the adapter that screws in where the oil filter use to go on the block.
    Check out the pic here:
    http://www.mercruiserparts.com/Show_...And+Crankshaft
    Larry
    Old 09-10-2012, 11:11 PM   #3
    husker_fan's Avatar
    My Model: 192 Barchetta
    My Engine: 4.3L Alpha I
    Send husker_fan:
    Every Chevrolet I've ever known has either put them there or at the top rear of the block just behind the intake manifold. Rambling now but a good rule for all oil senders is they usually won't be far from the oil pump.
    Old 09-11-2012, 01:41 AM   #4
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    Thanks Larry & Husker! You guys have confirmed my fears that it is buried under there. I guess I better start looking for a really skinny midget that I can shove down in there....oh wait, I have kids! Guess it will be another day of boat training for the kids this weekend!
    2001 Shabah Z275 ST
    Old 09-11-2012, 02:12 AM   #5
    Sometimes it's easier to pull the exhaust manifold csterner.
    Larry
    Fuel Gauge or Sender unit andyc Sea Fox - Mariah Talk 5 06-06-2012 01:47 AM
    Taking Temp Sender Out and Back In? Snoopinrob Mercury MerCruiser 0 07-01-2011 07:20 PM
    Which GPS unit blockp Original Mariah Talk 4 10-21-2008 03:40 PM
    Changing fuel gauge and sender,windshield parts Richard Keirsey Boating 101 2 09-08-2008 02:58 PM
    Alpha 1 Trim sender repair Z 202 Mercury MerCruiser 2 08-28-2007 01:34 PM
    There are 229 users
