lower unit alpha one cracked
Old 05-20-2012, 04:24 PM   #1
michaelb is currently offline
My Model: Talari 22
My Engine: 5.7 lt Brava I
Send michaelb:
Default lower unit alpha one cracked
just discovered my lower unit (aplha one, 96, 5.7 lt, talari) is cracked, half circle about the size of a baseball and wont hold any gear lube. can these be welded? if so wondering about the success rate of welding, has anyone done this?
thanks
michaelb
  • Old 05-20-2012, 07:16 PM   #2
    Default Re: lower unit alpha one cracked
    I welded up a Cobra drive on my old boat , it had a hole punched in it from a underwater obstacle. It worked for 2 seasons and then gernaded.
    It sounds like your drive had a leak and accumulated water inside. If it cracked that much you probably have other damage to deal with also , not to mention a reseal of the drive at the least.
    My opinion is get a new lower unit. I wouldn't trust it after freezing.
    Larry
    Old 05-21-2012, 08:30 PM   #3
    DFZ272 is currently offline
    My Model: Z272 Barchetta
    My Engine: 7.4 Bravo III
    Send DFZ272:
    I agree with Larry. Keep ur eyes out for a decent used one too. There a lot of older Alphas out there. You may can find a junk boat someone's wife wants out of the yard. Good Luck
    1995 Z272 Barchetta
    oil leak at lower unit stepchild_7 Mercury MerCruiser 1 11-11-2010 11:58 PM
    Lower Unit will not engage All In Original Mariah Talk 5 11-04-2009 04:52 PM
    Lower unit switch? Z212NH Original Mariah Talk 5 05-31-2009 12:03 PM
    Alpha drive cracked shoc Mercury MerCruiser 8 04-30-2009 08:31 PM
    i/o lower unit gear oil bryce6horse Mercury MerCruiser 1 04-25-2008 03:53 PM
    Total Members: 18,995
    Total Threads: 13,326
    There are 272 users
