Hesitation
Old 11-23-2011, 11:28 PM   #1
shabah929 is currently offline
My Model: 202 shabah
My Engine: 350mag
Send shabah929:
Default Hesitation
I’ve got a problem that I have been trying to fix for 2 years now and I need some help. The problem is in acceleration the boat starts and idles great but when I come out of the hole it falls on its face. The boat will kind of backfire before it takes off once it backfires it goes ok but it still lacks power. We also checked the timing and it seems to be a bit off it runs better with the ground wire that set the ignition to stock timing hooked up makes no since to me. Just wanted to know if anyone else has had any problems like this. Also it’s a 350 mag and my brothers 3.4l v6 will eat it alive out of the hole. Thanks for all the help.
  • Old 11-23-2011, 11:40 PM   #2
    Default Re: Hesitation
    If you do a site search for 'accelerator pump' or 'carburetor' you should find lots of threads on hesitation problems. You can also have a look at this particular thread.
    Old 11-24-2011, 12:04 AM   #3
    64*thunderbolt's Avatar
    64*thunderbolt is currently offline
    Status: SHABAH Z210
    My Model: SHABAH Z210
    My Engine: 5.7 EFI ALPHA1
    Send 64*thunderbolt:
    Sounds like a lean issue. starved for fuel , EFI? I think i`d start with fuel filters. good luck
    Old 11-24-2011, 12:39 AM   #4
    My Engine: 350mag
    Send shabah929:
    The boat is carbureted and I put a new filter on each year and I’ve put new plugs in it. The guy that works on my boat was thinking it might be the ignition because of the timing issue.
    Old 11-25-2011, 02:05 AM   #5
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    I would start by checking the advance mechanism in the distributor. Take off the distributor cap and give the rotor a twist, it should move freely and return via the advance springs. If it doesn't... that is most likely your probem and you will have to determine why it isn't free, lack of lubrication, broken spring etc.
    Another way to check if the advance is working properly is to get your hands on a timing light with an advance knob. You should be able to look up the advance curve (timing vs. RPM) in a service manual and verify it with the timing light.
    Good luck.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 11-25-2011, 10:50 PM   #6
    Status: SHABAH Z210
    i`m not sure about these, but my last boat had a filter {screen } inside the pickup tube inside the fuel tank.it got stopped up with trash inside the tank.i tiried everything i could think of before i found the problem.it would idile all day, soon as you hit the throttle it would bog down and die. also check the coil for low voltage output.
    Old 12-07-2011, 08:29 PM   #7
    DFZ272 is currently offline
    My Model: Z272 Barchetta
    My Engine: 7.4 Bravo III
    Send DFZ272:
    I agree with Steve. Put a good timing light on it. It is a fairly easy check, and essential before trying any carb tuning.
    Happy Boating
    Dan
    1995 Z272 Barchetta
    Old 05-23-2012, 02:37 AM   #8
    My Engine: 350mag
    Send shabah929:
    Does anyone have any thoughts on an ignition sensor ive heard this migh fix the problem.
    Mercruiser 496 Mag hesitation on top end sdf1jaj Mercury MerCruiser 7 10-07-2011 01:04 PM
    3.0L Mercruiser LX 1992 Hesitation Juno Mercury MerCruiser 4 09-21-2010 04:09 PM
    There are 434 users
