Starter Issue
General Maintenance
Old 09-26-2010, 04:58 PM   #1
ginodesico is currently offline
My Model: Z255 shabah
My Engine: 7.4 L Bravo III
Send ginodesico:
Default Starter Issue
I have a 1996 Z 255 Shabah w/ 7.4 L Mercrusier, Bravo Three. When I try to start the engine, I get clicks. After a few tries, it will start. I have replace the ignition switch, brand new starter, new battery & a new starter relay solenoid. Why do I keep getting this same result, click, click, click, click, then fire up. Any ideas would be helpful. All terminals are cleaned, good ground, connections are good.
  • Old 09-27-2010, 12:35 AM   #2
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    Default Re: Starter Issue
    I realize you have a new starter and starter solenoid, and have checked the wiring, but it sounds like it's either the starter solenoid, the connection from the battery to the starter solenoid, the connection from the starter solenoid to the starter, or the starter motor.
    Rather than just replacing parts, shotgun-style, would advise you actually trouble-shoot the problem to identify the fault. If you wish to do that, I can give you direction.
    Jim
    “The bitterness of poor quality is remembered long after the sweetness of low price has faded from memory.” - Aldo Gucci
    Click Here --> Help Support The Mariah Owner's Club <-- Click Here!
    Old 09-27-2010, 03:23 AM   #3
    Or you can have a look at my tutorial on diagnosing starter problems.
    Starter huntnfish Mercury MerCruiser 6 07-25-2010 04:41 PM
    Starter question PROPNUT Mercury MerCruiser 11 07-09-2010 06:36 PM
    Bad starter? Dogloop Mercury MerCruiser 9 07-03-2009 09:20 PM
    Mercruiser 4.3 starter azboatman Mercury MerCruiser 4 04-09-2009 03:04 AM
    Help with starter issues MariahShabah3.0 Original Mariah Talk 10 09-10-2007 06:04 PM
    There are 392 users
