What should I do? Cracks in block but not leaking!
Old 05-06-2011, 04:18 AM   #1
Lakeside's Avatar
Lakeside is currently offline
My Model: 215 Jubilee
My Engine: 5.7L Bravo III
Gallery Images: 12
Send Lakeside:
Default What should I do? Cracks in block but not leaking!
Hey Mariah friends, I'm in a delima...
I purchased a 2001 Mariah Jubilee 215 with 5.7 / 250hp Bravo 3 from my sister/brother-n-law last year. I initially had it inspected before purchasing it, and they told me everything looks good, and it runs good. When I had it winterized last year, the boat serviceman told me he found a crack on each side of the block (you really have to get your head underneath the bottom side of the block to see the crack, and there's a crack on both sides). The serviceman said it's not leaking water, but he thought it's only a matter of time. This Spring before taking it out on the lake, I took it to another shop to get a second opinion, they ran it for a long time, and said they too saw the crack on each side, but it is not leaking any water, and they checked the oil, and it's not leaking water in the oil either. My question to my Mariah friends is what do I do? I simply cannot afford to purchase a new block or r&r. Since it's not leaking, do you think it will last ???
Should I put JB weld on these cracks to get a longer life out of my engine? I'm hoping someone out there has delt with a similar problem, or has known someone with a similar situation... The boat serviceman stated that he's never seen a block that shows visible signs of cracks that did not leak even after running it for a while. I talked to my brother-in-law about it, and he said 3 or 4 years ago he through a couple of rods in the engine and it seized up on the lake. He said it cracked the block, but he did an r&r on the engine after that happened. He spent $4079 on a long block, $433 for a coupler, filter, oil, and $960 in labor (about $6000.00). The year after that, he found that the gimbal ring was bad, removed the gimbal ring, and the bell housing, and installed a new bell housing and a steering pin assembly, and spent $2000 so I felt like I was getting a completely restored engine when I bought the boat. Sorry for the long note, I just wanted to give the readers some history on the boat to help me figure out what to do to with my problem above. Any suggestions?
  • Old 05-08-2011, 12:11 AM   #2
    Lakeside's Avatar
    Gallery Images: 12
    Send Lakeside:
    Default Re: What should I do? Cracks in block but not leaking!
    Do you think JB Weld will work on these cracks, or is there a better product out there? Any advice is much appreciated!
    Old 05-08-2011, 03:06 AM   #3
    I've heard of people using JB Weld successfully and it probably wont hurt anything in your situation.
    Lakeside (05-16-2011)
    Old 05-12-2011, 09:13 PM   #4
    845paulg is currently offline
    My Model: Shabah Z 272
    My Engine: 7.4 L MPI Bravo III
    Gallery Images: 12
    Send 845paulg:
    Go with the JB weld. You have nothing to lose. Go have fun. Check the situation periodically. If a leak starts, it is likey to be minor so it might end your day but wont leave you stranded in the middle of the lake.
    Thank you 845paulg for this useful post!
    Old 05-12-2011, 09:27 PM   #5
    z275st's Avatar
    z275st is currently offline
    Gallery Images: 33
    Send z275st:
    Years ago, with my first boat, I failed to get it winterized in time. the block froze and leaked into the bilge but not into the oil. The shop welded the crack and it never leaked again. I would either have it welded now or just wait to see if it ever leaks and do it then. If you cover the area with JB Weld it may make it difficult to arc-weld if you ever need it done.
    Just my 2-pennies worth
    John
    2001 Mariah Z275st
    496HO Bravo1
    Old 05-19-2011, 02:33 AM   #6
    Lakeside's Avatar
    Gallery Images: 12
    Send Lakeside:
    Well, I picked up my boat from the shop today, and talked with the lead mechanic. He said he ran the boat for a long time in the shop and even took it out to the river to run it on a full load. He checked the areas that show evidence of a crack on each side of the block and found it not to be leaking at all... and the oil was fine. No problems... He said, he's never seen a crack that didn't leak. He said not to worry about it; just run it... watch the temperature, check the oil periodically, and just run it... I asked him about the JB weld, and he said he would not do this because you would have to sand paper around the cracks to get the paint off so the JB weld will adhere to the block (not the paint), and you might realize that there are not cracks under the surface, or you could make the cracked area worse... He agreed with the above post, that covering the area with JB weld could make it difficult to weld it if a problem ever occurs... So I took all this as good news, and I don't have plans to do anything, but take it out and have a good time.
    Old 05-19-2011, 04:09 PM   #7
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    Interesting topic. Thanks for following up. I hope it provides good times for a long time.
    Gear oil leaking??????? sharpvet03 Mercury MerCruiser 1 05-11-2010 06:48 AM
    Cracks on deck floor - 2010 Mariah R19.9 bailcam Sea Fox - Mariah Talk 26 04-04-2010 12:06 AM
    Help! My Dico is leaking..... Brian General Maintenance 2 03-27-2010 01:23 PM
    Leaking Gear Oil 300sflyer Mercury MerCruiser 4 03-31-2008 02:00 AM
    cracks in floor pan under engine mount luke Original Mariah Talk 1 02-22-2008 12:21 PM
    There are 329 users
