New 4.6 Mercruiser Owner - Lots of questions
Old 03-19-2011, 02:20 PM   #1
kelster1574 is currently offline
Send kelster1574:
Default New 4.6 Mercruiser Owner - Lots of questions
I recently purchased an 1991 18' Diablo with a Mercruiser 4.3 Alpha One engine (sorry, typo in the title and it will not let me change it) . I have always owned outboards so this is completely new to me. Are there any "need to know" things that will save me in the long run. The motor only has 204 hours and has had regular service. Thanks for youe help.
  • Old 03-19-2011, 07:56 PM   #2
    Default Re: New 4.6 Mercruiser Owner - Lots of questions
    I usually change the oil & filter as well as my gas line fuel/water seperator filter in the fall but in your case i would do it in the spring & fall this year unless you are absolutely certain the work was done before it was put away for the winter.Add a fresh tank of mid range gas & i would also add a bit of fuel stabilizer to the tank first to deal with any old gas in the tank. I also change my spark plugs every two years but again, since the boat is new you might want to have a look at them to see what condition they are in.
    As for the outdrive, changing the outdrive lubrication is absolutely necessary in the fall.
    In the fall make sure you get the engine winterized if there is any chance of freezing in your area. Failing to do so can cost big $$$
    kelster1574 (03-22-2011)
    Lots of Questions MX18 Introductions 9 03-18-2011 07:13 PM
    New owner, couple questions if you please midwest mariah Original Mariah Talk 4 07-14-2009 07:06 PM
    New member with lots of questions! lmuearl Introductions 2 04-01-2009 04:34 PM
    new owner has questions geiffert Original Mariah Talk 3 05-28-2008 02:34 AM
    New owner with questions turfguy99 Original Mariah Talk 3 05-05-2008 01:30 AM
    There are 285 users
