Intermittent start 2001 20' Shabah 5.0 Merc
Old 07-01-2009, 05:19 PM   #1
Londoner is currently offline
My Model: 2001 Mariah Shabah 20' 5.0L Merc
Send Londoner:
Default Intermittent start 2001 20' Shabah 5.0 Merc
Hi all. First post. Great website.
The Mariahs are beautiful boats.
Our boat has an intermittent starter issue. When it cranks, it starts and runs fine. It only has 160hrs on it.
My Father-in-law wants me to change the starter but I'd like to diagnose it a bit first. I see that a few people have problems with the neutral start swtich, is there any thing else i could check ?
Londoner
2001 20' Shabah 5.0 Carbed Merc
  • Old 07-08-2009, 01:59 PM   #2
    markkearns's Avatar
    markkearns is currently offline
    My Model: 1994 241 Davanti
    Send markkearns:
    Default Re: Intermittent start 2001 20' Shabah 5.0 Merc
    I am working on the same issue. We pulled the starter and its fine. We also checked the selinod and thats fine. Then we looked at the wiring harness and saw some exposed, melted wires. They were to close to the manifold.
    Hope this helps.
    Old 07-08-2009, 03:35 PM   #3
    Send Londoner:
    Definitely, thanks for the input. I will check the next time i am near the boat.
    I'm kinda hanging my hat on an electrical issue.... if not i gotta eat some crow from the F.I.L.
    Cheers,
    Londoner
    Old 07-08-2009, 03:51 PM   #4
    SEMIJim's Avatar
    SEMIJim is currently offline
    My Model: 182 Barchetta
    Send SEMIJim:
    When it doesn't crank, can you hear the starter relay go *click*? If so: It's either the starter relay contacts or the starter motor. If not: Odds are it's something up-stream (ignition switch, wiring).
    Jim
    Old 07-08-2009, 04:06 PM   #5
    Send Londoner:
    Is the starter relay mounted on or near the motor?
    I do hear something clicking on top of the motor (possibly near the carb) but haven't had the chance to locate exact location of the clicking.....
    Londoner
    Old 07-08-2009, 04:17 PM   #6
    SEMIJim's Avatar
    Send SEMIJim:
    I would assume so. They usually are.
    If you hear something go *click* when you turn the ignition key to the starting position, odds are it's the starter relay. Can't think of anything else it would be.
    Jim
    Sx18 Will Not Start andyc Sea Fox - Mariah Talk 6 08-03-2013 11:44 PM
    Intermittent Electrical Problem jwpilger General Maintenance 13 08-13-2009 02:44 AM
    Advice for proper propeller for 2000 218 Shabah 5.0 merc I/O 250 H.P. rhtzi099 Original Mariah Talk 0 04-28-2009 12:18 AM
    intermittent shutdown love2boat Volvo Penta 6 07-14-2008 02:41 AM
    2001 Merc 6.2 High Hours greencanuck Original Mariah Talk 8 04-05-2008 12:05 PM
    There are 359 users
