Mercruiser 4.3 starter
Old 04-07-2009, 04:13 PM   #1
azboatman's Avatar
azboatman is currently offline
My Model: 1999 Shabah 182, Mercruiser 4.3L, Alpha One
Gallery Images: 3
Send azboatman:
Default Mercruiser 4.3 starter
Anyone know how hard it is to replace a starter for a mercruiser 4.3 v-6 engine? Also, does anyone know where to pick up a starter for a good price? How common is it to damage the teeth of the flywheel if the starter goes bad? Had a marine mechanic tell me the mercruisers are bad for breaking teeth on the flywheel if the starter goes bad. So far, he is quoting me over $1000 to replace both if needed.
Any help would be appreciated.
Thanks.
AzBoatman
  • Old 04-08-2009, 12:22 AM   #2
    Default Re: Mercruiser 4.3 starter
    I do know its a pain to get at the bolts on the starter and once removed you really have to rotate the flywheel to check the ring gear for any damage/wear.
    When you replace it you have to use a Marine starter. Dont use an Auto starter as they are not sealed for sparks. A $1k bill for both jobs isn't far out of line.
    As a platinum contributor you have access to our manuals!
    Old 04-08-2009, 01:45 AM   #3
    jeffryb is currently offline
    My Model: 1993 19ft 1900z 4.3lx alpha one
    Send jeffryb:
    Actually, it was quit easy to change the starter. If you have the SS interior the back bench seat tilts forward then unscrew the side panel and then you can lay down on your side and everything is right there. As far as the flywheel I didn't mess with that I changed my starter for other reasons.
    Old 04-08-2009, 04:10 AM   #4
    azboatman's Avatar
    Gallery Images: 3
    Send azboatman:
    Thanks to you and Mikey for the info. How much did you pay for the starter (marine) and where did you buy it from?
    AzBoatman
    Old 04-09-2009, 03:04 AM   #5
    Send jeffryb:
    You know I can't remember the exact price but it was right around $200 bucks and I bought it at a local marina.
    Mercruiser Shifter Recall Threejakes Original Mariah Talk 10 09-09-2011 01:06 AM
    Starter motor SX18 Vilanova Mercury MerCruiser 3 02-01-2009 08:11 PM
    5.7 L Mercruiser 300sflyer Mercury MerCruiser 8 07-29-2008 04:42 PM
    Help with starter issues MariahShabah3.0 Original Mariah Talk 10 09-10-2007 06:04 PM
    There are 278 users
