Extra power Mercruiser 3 litre
Old 04-18-2013, 02:38 PM   #11
Default Re: Extra power Mercruiser 3 litre
Yep, ya gotta remember the max prop horsepower the 180 is rated for is 210. Anything over that might lead to transom issues and the extra weight of a V8 will really make your Smart Tabs work to keep the bow down and the stern off the bottom.
Andy b likes this.
  • Old 04-18-2013, 02:55 PM   #12
    95gts's Avatar
    95gts is currently offline
    My Model: Shabah 182
    My Engine: 3.0L
    Gallery Images: 4
    Send 95gts:
    Unfortunately a 4cyl to v6 or v8 swap isn't simple or straight forward, the engine mounts are different and so is the upper outdrive, it has a different gear ratio for the 4 banger. As the owner of an 18 footer with a 3L I can say that having two different props will make the boat much more usable. For cruising and light loads I use a 3 blade 21 pitch, for watersports and and an awesome holeshot I use a 4 blade 19 pitch.. 25-28mph is a comfortable cruise speed with the 21 pitch 3 blade, 22-25 is comfortable with the 19 pitch 4 blade.
    Old 04-18-2013, 03:06 PM   #13
    4.3 will bolt in with no mods to the hull. All you need is the 4.3 motor mounts , and the drive or regear yours.
    Buy another boat.
    Old 04-18-2013, 03:09 PM   #14
    95gts's Avatar
    My Engine: 3.0L
    Gallery Images: 4
    Send 95gts:
    The 4cyl mount is in the front of the engine, the v6 and v8 have mounts on the sides of the engine.. or am I missing something?
    Old 04-18-2013, 03:13 PM   #15
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Another issue with over powering a 180 is length,
    Stability at the top end of my range now (48-50mph) gets a bit light!
    Not sure I’d want to go much faster in this boat! I could see it swapping ends quite easily.
    Old 04-18-2013, 03:18 PM   #16
    The motor mount towers are there , just not used by the 3.0.
    Maybe I'm wrong.......it is early.
    Why would they manufacture a hull for each engine/drive package? A lot of extra work.
    Old 04-18-2013, 03:23 PM   #17
    95gts's Avatar
    My Engine: 3.0L
    Gallery Images: 4
    Send 95gts:
    I agree, it's the same hull whether it's a 4, 6, or 8. Mine being a 4 has nothing there to mount the 6 or 8, so holes would need to be drilled in the stringers for the new mounts.
    Old 07-26-2019, 09:05 PM   #18
    okhamis is currently offline
    My Year: 2010
    My Model: 18 SX
    My Engine: 3.0 Alpha One
    Send okhamis:
    My Mercruiser 3.0 on Alpha one is definitely under powered for the weight of the Mariah 18 SX,I need to overhaul the engine and I am now considering to upgrade it to a 4.3 V6....from the above thread it seems a straight bolt on right? will we have to do modifications for the exhaust? will the Alpha one sustain the additional power (assuming no modifications to be made on the shaft)
    Old 07-27-2019, 03:53 AM   #19
    As the previous posts stated, it is a fairly straight forward swap from a 3.0 to a 4.3 and the Alpha 1 will handle up to 300 hp which is far more than the 4.3 liter will put our or the 180 hull can handle. You may though have to change out the gearing in the Alpha 1 because of the increased 'grunt' of the 4.3. Personally..... i would just sell that SX18 and buy something with a 4.3, 5.0 or 5.7 in it.
    Old 07-27-2019, 08:22 PM   #20
    My Year: 2010
    My Model: 18 SX
    Send okhamis:
    Thanks Mike.
    I did not know the Alpha 1 would be able to handle upto 300 bhp !
    5.7 L Mercruiser 300sflyer Mercury MerCruiser 8 07-29-2008 04:42 PM
    5.7 Litre and 4.3LX Alpha One, is that original? ale5jandro Original Mariah Talk 14 07-16-2008 09:01 PM
    My Extra-Curricular Activity... MariahMan Chit Chat/Off-Topic 10 05-12-2008 05:28 PM
    There are 248 users
