Fuel pump - warm starting question
Old 09-25-2020, 12:33 AM   #1
Flying Toaster is currently offline
My Model: Shabah 202
My Engine: 5.0L Alpha 1
Send Flying Toaster:
Default Fuel pump - warm starting question
Hello All. My first post. Recently purchased a '99 Shabah 202 with the 5L Merc.
-Carb recently rebuilt.
-Starts fine when cold.
-After cruising for a bit, I stop & shut the engine off for a minute while the kids swap places on the towable. I can start it right back up if I try within a minute of shutdown.
-If I wait more than 4-5 minutes to try to start, the engine will crank for a solid 5 seconds before it fires.
I'm guessing there is no check valve in the fuel system or if its built into the fuel pump, perhaps thats the source?
The decal on the side of the fuel pump is J1171.
Thoughts on above symptoms?
Thank you. -John
  • Old 09-25-2020, 12:38 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: Fuel pump - warm starting question
    The heat from the engine could be boiling the fuel out of the carb bowl or even boiling the fuel in the fuel line, causing a vapor lock.
    Do you shut off abruptly or let idle for a period of time to cool things down?
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 09-25-2020, 05:00 PM   #3
    Thanks Steve for the quick response. I'd have to say I lean towards abruptly. For instance, I will slow down from 25mph, come to a stop, idle for 20-30 seconds tops, shut it off while we pull the kids back to the boat. They switch out, I go to start about 4 minutes later and thats when it cranks longer than usual. (I leave the blower going the entire time.)
    I hope to go back out this Sunday, I will pay attention to allowing it to idle & cool down to see if that makes a difference.
    If what you suggest is the case, I wonder if there is any value in an aluminum carb spacer, heat shield on the fuel line? (typical classic muscle car tactics)
    Thank you -John
    Old 09-25-2020, 05:18 PM   #4
    My Model: Z280
    Do you have a mech or electric fuel pump? If electric then the issue is most likely the fuel line heating. If mechanical, it could be either the carb or line.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Starting question Branamoi General Maintenance 2 10-10-2019 08:45 PM
    Need fuel pump 4.3 chrissbee77 Mercury MerCruiser 12 08-17-2016 11:26 PM
    Fuel Pump swoodworth Original Mariah Talk 8 08-07-2014 02:24 PM
    Stupid Question: Starting my Z272 Barchetta JoeDoyle Original Mariah Talk 9 08-18-2011 04:44 PM
    Is this the fuel pump ? shoup2010 Mercury MerCruiser 6 07-11-2010 02:24 PM
    There are 249 users
