'96 4.3LX Head Gasket
Old 06-21-2020, 03:13 PM   #1
cjgoetz is currently offline
My Model: 180 Shabah
My Engine: 4.3l Alpha One
Send cjgoetz:
Default '96 4.3LX Head Gasket
Hoping you guys can give me some quick help.
Put the boat up for the winter and finally was able to pull it out this weekend to start getting it ready for July 4th weekend.
Ended up finding milky oil. Not good of course.
We don't believe it's a cracked blocked as we tried to be good about putting extra Antifreeze thru the system when winterizing.
When I fired up the boat to give it a quick check, (yes, stupid me for not checking the oil first) it had a slight miss in it. Thinking back, we had a slight miss in it before we put it up for the winter and A time or two before that.
I have just enough time to replace the Head Gaskets if that's the case but of course, being able to get the proper Head Gasket matters.
Can anyone tell me off hand what I should be using? Can I just run to the local AutoZone or Napa and grab a Head Gasket kit? The motor is stock and for us, works great. This is the 12 bolt intake.
Thanks in advance.
Chuck
'96 Mariah 180 Shabah
4.3LX Alpha One
  • Old 06-21-2020, 05:55 PM   #2
    Tlolesen's Avatar
    Tlolesen is currently offline
    My Model: 182
    My Engine: 4.3 merc
    Gallery Images: 3
    Send Tlolesen:
    Default Re: '96 4.3LX Head Gasket
    I have a 2001 Shabah 182 with the 4.3 last year I had oil in the water and after a compression test turned out to be the exhaust manifold on the starboard side the water jacket was cracked and letting water in. So I wouldn't assume head gasket tell you get it checked out.
    Old 06-21-2020, 11:46 PM   #3
    Send cjgoetz:
    Thanks Tlolesen. We'll make sure to check out the manifolds.
    4.3LX Alpha One
    Old 06-21-2020, 11:54 PM   #4
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    You can check if it's a head gasket by performing a compression test or even better a leak down test.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 06-24-2020, 05:11 AM   #5
    Send cjgoetz:
    Well, it turned out to be a cracked block so for the moment our season is over. Now to find out what an engine is going to cost me. Capable of doing it myself but wife is insisting on hiring it out since we have so much more to do.
    4.3LX Alpha One
    Old 06-24-2020, 03:14 PM   #6
    My Model: Z280
    That is a shame. Mercruiser sells re manufactured long blocks or you can go with a company like Jasper Engines.
    https://www.mercurymarine.com/en/us/...es-longblocks/
    https://www.jasperengines.com/marine-engines
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Manifold Gasket Replacement jayhawkboater Sea Fox - Mariah Talk 2 10-10-2014 05:35 PM
    Wanted: volvo penta carb gasket set andybailey Mariah Parts For Sale & Wanted 9 07-19-2013 10:53 PM
    1999 merc 3.0l blown head gasket silver04roush Mercury MerCruiser 5 08-22-2010 05:12 PM
    Windshield screw cover gasket shoot001 Original Mariah Talk 2 02-17-2009 11:55 AM
    There are 362 users
