Shifting problems
Old 09-11-2017, 03:30 PM   #1
Chief Ray is currently offline
My Model: 202SS
My Engine: 5.0
Send Chief Ray:
Default Shifting problems
Have a 2000 Shabah 202 with a 5.0 Mercruiser, my problem, taking it out of forward it is still in gear past the neutral. Pull the lever back toward reverse a bit and it finds neutral. It started this after we had the lower unit serviced, could the mechanics have changed the linkage? Is this a quick fix?
Thanks Ray
  • Old 09-12-2017, 02:52 PM   #2
    pole trick is currently offline
    My Model: 180 Shabah
    My Engine: 4.3 Merc
    Send pole trick:
    Default Re: Shifting problems
    I would take it back to the marina or at least call them and see if they can come and service it correctly. They either put something back together wrong or misadjusted it. if it worked correctly before they worked on it, then it's their problem to make it right
    Old 09-24-2017, 01:56 PM   #3
    My Model: 202SS
    My Engine: 5.0
    Send Chief Ray:
    It was an adjustment problem which the Marina mechanic had fixed in a few minutes, No charge. Now a happy boater again.
    Thanks for the advise.
    Ray
    Old 09-24-2017, 07:23 PM   #4
    Tinman2809 is currently offline
    My Model: Barchetta
    My Engine: 4.3 Yamaha stern
    Send Tinman2809:
    Glad it was an easy fix
    Clunk noise when shifting Tlolesen Mercury MerCruiser 2 08-05-2017 02:37 PM
    Shifting problem michaeldriver Original Mariah Talk 1 07-22-2013 03:49 AM
    Shifting MariahCharlotte Mercury MerCruiser 1 06-01-2011 05:32 PM
    Control arm not shifting out of forward Lunaticutah Original Mariah Talk 3 06-26-2009 04:14 PM
    question about shifting 180diablo Mercury MerCruiser 0 07-24-2007 09:58 PM
    There are 343 users
