2001 245 jubilee. 4 terminal ignition switch
Old 08-26-2017, 01:34 AM   #1
Plandreth is currently offline
My Model: 24.5 Jubilee
My Engine: 5.7 Bravo 3 merc
Send Plandreth:
Default 2001 245 jubilee. 4 terminal ignition switch
4 terminal ignition switch went out. What is the accessory wire for on a 4 terminal. Can it be converted to a 3 terminal switch
  • Old 08-26-2017, 07:23 AM   #2
    porker is currently offline
    My Model: 209 Talari
    My Engine: Volvo Penta 7.4L/SX
    Send porker:
    Default Re: 2001 245 jubilee. 4 terminal ignition switch
    Accessory wire should only power your radio, power outlet, etc. and not your engine. I am sure you could combine your accessory and run circuits together if you really wanted to convert your ignition switch to a 3 terminal, but I don't understand why you would want to do that. I recently replaced my broken 4 terminal switch with Sierra MP41040 and it was pretty much an exact match for less than $20.
    4 terminal ignition wiring diagram Hunter12345 Boating 101 1 07-19-2016 05:20 AM
    Ignition switch Threejakes Original Mariah Talk 7 06-20-2016 03:25 PM
    Ignition Switch blatt88 General Maintenance 0 09-27-2014 01:38 AM
    Ignition Key Switch? Chickman Original Mariah Talk 4 04-29-2014 06:15 PM
    Ignition switch Provo Original Mariah Talk 1 08-15-2009 09:21 PM
    There are 340 users
