Vortec engine????
Old 08-30-2017, 12:25 PM   #1
Reaper22 is currently offline
My Model: Z212
My Engine: 350 Magnum alpha one
Send Reaper22:
Default Vortec engine????
I got my new engine installed and dealer said they ordered a vortec engine because that was what came out, It was a long block so they used my intake and exhaust, My question is the boat is a 95 Z212 with a 350 magnum, The valve covers bolt thru the center but the intake has 12 bolts and I was checking around and vortecs use an 8 bolt manifold, I am confused, So is it possible for this engine to be a vortec? Thanks...
tbrookens likes this.
  • Old 08-30-2017, 12:43 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: Vortec engine????
    Check the casting numbers on the heads. You can Google the number and determine if they are Vortec heads.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 08-30-2017, 02:08 PM   #3
    Scottie1961's Avatar
    Scottie1961 is currently offline
    Status: Gold Contributor
    My Model: Z202 Shabah
    My Engine: 5.7L Alpha One
    Send Scottie1961:
    I agree with Steve, you need to check the casting numbers but pre Vortec intakes won't work with Vortec heads. Make sure you're not paying for something you didn't get.
    1995 Mariah Z202 Shabah
    5.7 Alpha One Gen II
    Thank you Scottie1961 for this useful post!
    bibleg2015 (08-30-2017)
    Old 08-30-2017, 03:25 PM   #4
    My Model: Z212
    Send Reaper22:
    Thanks man, Is that number under the valve cover or on the end because it is all ready installed and from what I read vortec heads only take and 8 bolt manifold and mine are 12 bolt...
    Old 08-30-2017, 05:54 PM   #5
    My Model: Z280
    Yes the casting number is under the valve cover. You must remove them to view the number. You are also correct in that the Vortec heads have only 8 intake manifold bolts. These bolts also go straight up and down rather than on an angle. If it is a Vortec head the probable casting number is 10239906.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 08-30-2017, 11:14 PM   #6
    My Model: Z212
    Send Reaper22:
    Thanks man, I also called the engine builder and they told me it was not a vortec, True vortecs did not come out until 96 but it does have roller cam and roller lifters and this engine has plenty of power for my boat and they are built well and will last long time, This company has been in business for 40 years and they do give a 2 year warranty... Advance Marine engines
    Advanced Marine Engine - Boat Motors - Crate Engines - New & Remanufactured
    Old 09-04-2017, 03:09 AM   #7
    My Model: Z276
    Send Brian Belcher:
    "Vortec" was used on engines before the actual, new generation "VORTEC", fuel injected engines came out in 96. My sons 95 motor home has a Vortec 454.BUT, it's not the LS style one. It has a roller cam and all but it does not have the cathedral intake ports. I wonder if that's the same deal with the 350?
    4.3 vortec won't fire, help needed Budsybill Original Mariah Talk 27 05-22-2014 11:28 PM
    4.3 vortec or non-vortec chevybar Mercury MerCruiser 19 11-21-2012 02:18 AM
    Wanted: WANTED ! 4.3 Vortec marine engine L&K's Z 190 Shabah Mariah Parts For Sale & Wanted 3 06-03-2011 08:27 PM
    4.3L Vortec jetscat7 Mercury MerCruiser 9 02-12-2010 05:26 AM
    There are 363 users
