Ignition Key Switch?
Old 04-28-2014, 02:26 PM   #1
Chickman is currently offline
My Model: 200 Shabah
My Engine: 5.7 Mercruiser
Send Chickman:
Default Ignition Key Switch?
Guys, my 1996 Shabah ignition/key switch took a dump on me yesterday. Can I just replace it w/ a standard 3 way key switch? Anything special about it?
  • Old 04-29-2014, 03:16 AM   #2
    thedge2013 is currently offline
    My Model: 272Z barcheta
    Send thedge2013:
    Default Re: Ignition Key Switch?
    Yea you should be able to. I replaced mine with a regular switch then switched to an electronic keypad and didnt have any issues at all
    Old 04-29-2014, 05:38 PM   #3
    Yep, any standard marine grade ignition switch will work. Had the same issue on my Z250 and swapped with a "SeaSense" ignition switch with no problems whatsoever.
    Old 04-29-2014, 05:52 PM   #4
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    While you are talking about ignition switches, which member had an assortment to of original keys??
    Old 04-29-2014, 06:15 PM   #5
    He's listed in the "Original Parts" vendor list.
    Ignition switch & keys doaclnr Original Mariah Talk 8 01-09-2014 07:20 PM
    Ignition switch replacement - W,X,Y, or Z? chaddv Original Mariah Talk 11 07-10-2012 02:00 PM
    New Ignition Switch - Won't Start Dsg03svt Original Mariah Talk 6 04-11-2012 01:46 PM
    Problem with Ignition Switch lmdengler Original Mariah Talk 3 05-31-2011 12:43 AM
    Ignition switch Provo Original Mariah Talk 1 08-15-2009 09:21 PM
    There are 332 users
