Alternator upgrade
Old 05-18-2016, 01:38 PM   #11
Default Re: Alternator upgrade
I have the same isolator you have Paul and I think they might be rated for 120 but it's been a long time since I put mine in and I can't say for certain that's correct.
Sent from my XT1585 using Tapatalk
  • Old 05-18-2016, 01:43 PM   #12
    Txtruckerpaul's Avatar
    My Model: Z240 talari
    My Engine: 7.4 bravo III
    Send Txtruckerpaul:
    ok, thanks, Moto. Dummy me... I didn't even think about the isolator having an amp rating. I'm at my office now (yea, I'm getting lots of work done playing on the computer,lol) and will check it when I get home and look at it. I probably shouldn't have gotten that big of an alternator, especially if I'll have to change the isolator and other things for it to work
    Old 05-18-2016, 02:05 PM   #13
    I found the add a battery kit we have HERE showing 120. The ACR is part number 7610 and the whole kit number is 7650 of you are looking them up.
    Old 05-18-2016, 02:09 PM   #14
    Send Txtruckerpaul:
    I found mine on some old pics I had on my phone. It's the one rated for 120 amps. dangit!
    Old 05-18-2016, 02:37 PM   #15
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Paul,
    130A is a lot of alternator but bigger is always better, right? 130A alt will just charge the batteries faster or allow you to run a lot of electrical accessories and still charge the batteries. I have the standard 65A in my Z280 and it has no issue running my boat and charging 3 batteries, a group 24, a group 27 and a monster 4D. Do you have a monster stereo on your boat? A 65A alt should support up to almost 1000W without draining the batteries. Or do you do a lot of idle cruising? The alternator only puts out its max amperage at a specific RPM (>3000RPM). Your present alternator may have one or more of the rectifier diodes out which would only give you 1/3 to 2/3 of its rated output.
    If your ACR is rated at 120A you are probably OK. I doubt your 130A alternator actually puts out 130A unless you have some ideal conditions...but i cannot guarantee it.
    Motoxxx43 likes this.
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 05-18-2016, 02:42 PM   #16
    Good info Steve! I was unaware of the RPM at which the alternator put out it's rated amps. Similar to your experience I have not had any charging issues with the stock alternator and 2 batteries.
    Old 05-18-2016, 02:47 PM   #17
    Send Txtruckerpaul:
    Steve, I have a 400 watt stereo. A lot of our time on the water is spend either anchored in a cove with stereo going and engine off, or idling around the coves but we do pull a tube at higher speeds. I will cruise at full throttle some, too, but not all the time. I have thought about the "actual" output of an alternator. Like a lot of things, the advertised rating is somewhat higher than the actual, but not sure. I can't remember the group size of my two batteries. I think they may be 27's. I do remember they have something like 850 cold cranking amps
    Old 05-30-2016, 01:15 PM   #18
    Send Txtruckerpaul:
    Finally got the new alternator on. Left the original hot wire on the alt and ran an 8 gauge wire to the starter solenoid, too. Ran it at the lake all day and no problems!
    Old 05-30-2016, 01:52 PM   #19
    Good deal. What voltage was it running at? Where did you get the alternator?
    Old 05-30-2016, 02:02 PM   #20
    Send Txtruckerpaul:
    It ran almost 14 volts. Was big enough to keep both batteries charged all day. I got it on eBay. Can't remember the name of the seller
    Alternator allmaned Original Mariah Talk 6 08-17-2016 01:24 PM
    Alternator doaclnr Original Mariah Talk 9 06-21-2014 12:36 AM
    Alternator issues? bnussbaum Original Mariah Talk 5 06-05-2011 03:02 AM
    Alternator problem Captain D Original Mariah Talk 4 09-01-2010 01:29 PM
    Alternator jasfiveo Original Mariah Talk 3 05-15-2009 09:58 PM
    There are 244 users
