Bravo 3 prop seal leak
Old 06-01-2015, 02:39 PM   #1
Txtruckerpaul's Avatar
My Model: Z240 talari
My Engine: 7.4 bravo III
Send Txtruckerpaul:
Default Bravo 3 prop seal leak
Is it normal for the prop shaft seals on a bravo three to seep some oil after sitting up all winter? Just got mine out this morning to clean up and do spring maintenance and noticed a very small amount of drive oil from behind the props. I had new seals installed last season and had no problems. I have not fired the engine up yet
  • Old 06-01-2015, 07:21 PM   #2
    Default Re: Bravo 3 prop seal leak
    Pretty sure that is not normal. My Bravo did that due to a tweaked prop shaft. New shaft an seals no leak now. I've had the bass boat outdrive do the because of fishing line getting tangled in there.
    Old 06-02-2015, 02:53 AM   #3
    Send Txtruckerpaul:
    Cleaned the small oil drip off the skeg and ran the motor with muffs for a while and dis t see any more leak. Went to the lake this afternoon and ran it a few hours. Level never dropped in the reservoir. I dunno? Ill watch it and see if it leaks again this week
    Bravo 3 prop swap questions 99 Mariah 258 Prop Talk 17 05-06-2021 11:50 AM
    Bravo III Prop Shaft Discoloration Humpty Prop Talk 10 07-29-2014 07:12 AM
    Bravo 2 prop on a alpha 1 drive? dieselwiezil Prop Talk 1 07-14-2010 08:15 AM
    bravo 3 prop question jgreen Prop Talk 5 07-29-2009 04:42 AM
    2350Z/454/bravo 1 prop selection cleah Prop Talk 3 06-03-2009 10:37 AM
    There are 342 users
