New 1995 Talari Owner
Introductions
Old 07-17-2014, 06:52 PM   #1
alive307 is currently offline
My Model: 180 talari
Send alive307:
Default New 1995 Talari Owner
This is our first boat and we love it, From Houston Texas..
  • Old 07-17-2014, 07:35 PM   #2
    Default Re: New 1995 Talari Owner
    Looks good. Welcome aboard!
    Old 07-17-2014, 09:54 PM   #3
    Welcome to MOC!
    Old 07-17-2014, 11:21 PM   #4
    Mariah1's Avatar
    Mariah1 is currently offline
    My Model: Shabah Z198
    My Engine: 4.3 Alpha1
    Gallery Images: 9
    Send Mariah1:
    Nice
    Old 07-18-2014, 04:41 PM   #5
    ckolek's Avatar
    ckolek is currently offline
    My Model: z182 shabah
    Send ckolek:
    Welcome! I'm also from the Houston area. Lake Somerville is a Great Lake for boating!
    Old 07-18-2014, 04:59 PM   #6
    Smokymance's Avatar
    Smokymance is currently offline
    My Model: 182
    My Engine: 4.3L MerCruser Alpha 1
    Send Smokymance:
    Whats the difference between the Talari and Barchetta? i was told mine is a barchetta, but it looks exactly like this Talari.
    LM
    182 Barchetta 4.3L 4BBL V6, Alpha One, 21P SS Prop, 60# SX Smart Tabs.
    Old 07-18-2014, 05:04 PM   #7
    LM
    You should look a little closer. There is one obvious difference from both of your pics. Take a look at the shape of the side windows.
    Old 07-20-2014, 05:38 PM   #8
    Jnelsfd is currently offline
    My Model: Z220 Talari
    My Engine: 5.7 Bravo
    Send Jnelsfd:
    Looks good, I'm sure you'll enjoy it. We just bought our first boat as well, its a 1995 Talari Z220.
    Old 07-21-2014, 07:44 PM   #9
    Send alive307:
    Thanks everyone for the welcome...took boat out this weekend ran great. Only thing is the steering seems to be a bit off. when going straight the wheel is turned 90 degrees clockwise....Any ideas or fixes I can do my self or should I take to a marina?
    Old 07-21-2014, 08:32 PM   #10
    That should be a relatively easy fix. Remove the centre cap, remove the nut and the steering wheel, then centre & reinstall.
    But i do recall reading this bit of helpful advice for this problem on another boating site:
    My steering wheel was only 15 degrees or so out of sync.
    I put several inches of shims under the right side of my captain's seat. That fixed the steering wheel problem.
    Then, I noticed all the gauges were no longer centering in the vertical. Everything was running fine, so I determined the problem to be with the gauges themselves. I removed and replaced all the gauges with new ones. Since they were new, I was able to install them such that they centered to the vertical.
    Then I noticed the boat listed to starboard. So I bought some trim tabs. I run the starboard trim tab a bit higher than the port and everything was great.
    Then I noticed the other boats on the lake kept turning into me. No amount of complaining, horn blowing, etc would fix the other boaters, so I bought the lake and made it private. Now no one turns into me.
    Then I noticed the lake wasn't quite straight...............
    I think it was Andy b who tried this....
    looking to buy 1995 210 talari Toddr1 Original Mariah Talk 9 05-27-2014 01:36 PM
    1995 Talari question finleydj Original Mariah Talk 14 10-12-2012 12:34 AM
    1995 Z220 Talari bogiestg Introductions 2 08-16-2012 12:04 AM
    1995 mariah talari 707dog Mariah Boats For Sale & Wanted 0 11-30-2009 01:54 PM
    There are 362 users
