93 Diablo power steering pump
Introductions
Old 07-09-2014, 08:26 PM   #1
Henri Carr is currently offline
My Model: Diablo
My Engine: 3.5 leter Merc
Send Henri Carr:
Default 93 Diablo power steering pump
I have a 1993 18' diablo with a 4.0. The power steering pump is leaking from the rear mounting bolt. Does anyone know if that is possible.
  • Old 07-10-2014, 12:40 AM   #2
    Default Re: 93 dieblo power steering pumo
    Sounds like case is cracked at the mount.
    Check the lines good , they can be deceiving.
    BTW: Welcome to MOC Henri!
    Henri Carr (07-10-2014)
    Old 07-10-2014, 03:22 PM   #3
    My Model: Diablo
    Send Henri Carr:
    I pulled the pump and the fluid is coming from the rear mounting bolt. There seams to be a gasket at the top tread of the pump. Can that gasket be replaced without replacing the pump?
    Old 07-10-2014, 08:23 PM   #4
    Default Re: 93 Diablo power steering pump
    Part # for the stud is Quicksilver #16-41877.
    I can not find any info anywhere that there is a seal or gasket. But , you might try using a copper gasket for a 10mm bolt and see if that will stop the leak.
    I did read that there is a seat of sort that the stud sits in. Could the stud maybe be loose?
    Just a few thoughts to ponder.
    Old 07-11-2014, 09:50 AM   #5
    My Model: Diablo
    Send Henri Carr:
    I took the pump to a dealer and they did not know. I am going to use RTV and a copper crush gasket and hope that works. The bolt threads were almost striped as well.
    Thanks for your help.
    power steering cable bethk Original Mariah Talk 3 10-31-2021 09:36 PM
    Power Steering Fluid Barry Original Mariah Talk 0 03-02-2011 11:58 AM
    power steering freeman81 Boating 101 7 02-04-2011 06:53 PM
    2350 Z power steering cleah Mercury MerCruiser 2 09-09-2008 02:17 AM
    Power Steering boarder1010 Boating 101 2 07-08-2008 03:38 AM
    There are 327 users
