Gear lube bottle
Introductions
Old 06-06-2014, 05:12 PM   #1
savage is currently offline
My Model: shabah
My Engine: 350 mag alpha
Send savage:
Default Gear lube bottle
Hello I am a Mariah owner my first I love it even though its an oldie, its a 1993 shabah. I do have one question did they come with gear lube bottles for the lower unit? or is this something that is after market? I was told it was in the engine compartment but I dont see it.
  • Old 06-06-2014, 05:51 PM   #2
    Default Re: Gear lube bottle
    Your Mariah is right in the change over area. Late 1992 or early 1993 they started adding the Drive Oil Reservoir.
    What is the number on your drive ?
    The old Mariahs are just as good as the newer ones savage.
    BTW: Welcome to MOC!
    Old 06-09-2014, 02:33 AM   #3
    My Model: shabah
    Send savage:
    Thank you very much for your reply. sorry I didn't get back sooner I went up lake for a couple days. my drive # is 0f101481
    Old 06-09-2014, 03:25 AM   #4
    I can not find a commitment serial number where the reservoir became "std issue".
    It looks as though they were a option for the 1991-up Gen 2 drives(round reservoir)according to mercruiserparts.com. But , I know they were std on the 1996 - up drives(square reservoir).
    Sorry I can't pinpoint it for you , but I'll keep researching.
    Oil & Gear lube capacities & Std wiring colours mikeyt General Maintenance 1 07-16-2013 01:00 AM
    Water in gear lube xmac23 Original Mariah Talk 5 07-07-2013 02:59 PM
    Alpha 1 Gear Lube use problem sjrowan007 Mercury MerCruiser 8 05-09-2012 12:53 AM
    Alpha One and Gear lube jth21usa Mercury MerCruiser 1 07-16-2010 11:26 PM
    need help changing gear lube on alpha one outdrive. pimpadelic General Maintenance 9 07-01-2009 05:41 PM
    There are 285 users
