Removing swivel base
Introductions
Old 07-02-2013, 02:15 PM   #1
papineau is currently offline
My Model: R18 Diablo
My Engine: 4.3L
Send papineau:
Default Removing swivel base
Hi.
I have a Mariah Diablo, and I need to remove my fuel tank to clean it out, but to do so, I need to remove the seats and carpet to get to the tank. I can't figure out how to remove the base of the swivel seats/chairs. I removed the posts by removing the screws, but not the based onto which the posts were screwed on.
  • Old 07-02-2013, 03:02 PM   #2
    Default Re: Removing swivel base
    Not real familiar with the newer Diablos but...........I'm pretty sure you cannot just remove the fuel tank. At least not without cutting the floor out.
    Hopefully one of the SeaFox Mariah owners will chime in with better news for ya.
    BTW...........Welcome to MOC!!
    Old 07-02-2013, 03:21 PM   #3
    My Engine: 4.3L
    Send papineau:
    Thanks. The fuel tank is easy to get to. There's a floor board that is screwed and I can unscrew about 90% of it, and lift it up. The problem is there's about 10 inches of that board that goes under the seat base.
    Old 07-02-2013, 03:22 PM   #4
    Wouldn't it be easier to add your fuel tank flush then disconnect the fuel filler line at the tank and siphon everything out? Removing the floor and the fuel tank is a major job.
    mariah , removal , seats , swivel
    Anyone tried removing their side graphics? bbrophy58 Original Mariah Talk 18 02-08-2019 05:15 PM
    Removing Surface Rust ColoradoDiablo General Maintenance 1 02-15-2012 10:51 AM
    Which models were made in 2001? base-top of the line? nglauer Original Mariah Talk 10 07-15-2010 08:30 PM
    Stern Light Base lncoppola Original Mariah Talk 2 05-14-2010 03:42 AM
    Removing cushions jetscat7 Original Mariah Talk 0 02-09-2010 10:33 PM
    There are 254 users
