annie
Introductions
Old 10-15-2012, 08:12 PM   #1
Annie1962 is currently offline
My Model: mx19
My Engine: 6 cyl.4.2
Send Annie1962:
Default annie
first post. Looking for ways to access fuel tank on 1992 Mirah MX19
  • Old 10-15-2012, 08:15 PM   #2
    Default Re: annie
    Welcome aboard Annie. What are you trying to do with the fuel tank? Replace it? Or is it the fuel tank sender unit that requires work? Removing/replacing the fuel tank requires removal of the floor. Access to the fuel sender unit is just in front of the engine under a small flap in the flooring cover. Follow the fuel filler line down to the tank & it should be visible.
    Old 10-15-2012, 11:27 PM   #3
    Default Re: annie
    Welcome to MOC annie!
    As mikey stated there is a hatch , maybe 10"x28" just in front of your engine hatch or under your rear seat if it had the sport seats. Mine has a aluminum angle running down the edges.
    Larry
    Old 10-16-2012, 01:07 AM   #4
    My Model: mx19
    Send Annie1962:
    Default Re: annie
    What I am trying to do is remove water from a full gas tank.If I can access thru the sender unit hole I may be able to get the water out.
    Old 10-16-2012, 02:00 AM   #5
    Default Re: annie
    Sounds like you got the right approach. You can siphon a lot but your going to still have fuel/water in the tank. Use a suction pump to remove the remaining fluid. Then use Seafoam or another additive to your "fresh" fuel. Change out the filter run it for a couple tanks then change the filter again.
    There is still going to be "bad" fuel but the seafoam or other additive of your choice should cover it.
    Bad fuel is a pain in the butt , and you need to have patience. It will work thru as long as it hasn't sit for to long.
    Larry
    Old 10-16-2012, 03:34 AM   #6
    Default Re: annie
    Its doable thru the fuel sender unit access hole. Just tip the boat up so that the fuel moves to the back of the tank once u get the level down a bit. And Larry's got the rest of it covered.
    There are 231 users
