newbe
Introductions
Old 08-03-2011, 10:39 AM   #1
jbkkic is currently offline
Send jbkkic:
Default newbe
Hi everyone looking at 1995 shabah with 300hrs 5.7 efi I'm looking for info on quality of hull. Is made with wood or fiberglass stringers,do the transoms hold up well etc. marine plywood or the cheap stuff?
  • Old 08-03-2011, 01:43 PM   #2
    DFZ272 is currently offline
    My Model: Z272 Barchetta
    My Engine: 7.4 Bravo III
    Send DFZ272:
    Default Re: newbe
    Original series Mariah boats were built with pressure treated fir plywood for hull reinforcing. Which was them encapsulated in glass. Better than standard untreated marine plywood. Probably why they had a lifetime hull warranty. I have seen a lot of boats with "no wood stringers", they could say this because many of them had nothing to help strengthen the hull. My boat is a 1995 model and it has no blisters, no hairline cracks around fittings or anywhere else, no soft spots in the deck, upholstery frames, or transom. They are solid boats. Taken care of properly they will last a long time. If you decide to upgrade your membership you can read everything about them, really good information
    Dan
    Thank you DFZ272 for this useful post!
    jbkkic (08-03-2011)
    Old 08-03-2011, 03:08 PM   #3
    Default Re: newbe
    Dan
    What he said!
    jbkkic (08-03-2011)
    Old 08-03-2011, 07:15 PM   #4
    Send jbkkic:
    Default Re: newbe
    thanks ,this will be mt first IO any idea how fast this boat will be on the water 1995 shabah 5.7 efi?
    Old 08-03-2011, 07:25 PM   #5
    Send jbkkic:
    Default Re: newbe
    have you had any major issues with your boat? I love the way they look and sound but I want a boat to last. I'm still running a 1978 Glastron with a 115 Johnson.
    Old 08-04-2011, 12:13 AM   #6
    Default Re: newbe
    You do realise you are asking people who love their Mariah's (that's why most of us are members here) whether or not they are any good dont you?
    As for your other question, it depends on what size/model# boat. All you have told us is that the boat is a 1995 with a 5.7L. If its an 18' boat it will run like a bat out of hell. If its a 30' boat then the performance will be a little 'lacking'.
    Old 08-04-2011, 04:01 AM   #7
    Send jbkkic:
    Default Re: newbe
    I am here tying to make an informed decision. As owners of these boats who would no more about any problems,design,or construction issues than the fine folks here. I stopped a 1997 20ft Shabah on the river this summer to look it at because it sounded so good. Candy apple red gold trim beautiful inside and out. I found this other boat, seller does not say length it looks like a 20 or 22 foot boat in the pictures.
    Old 08-04-2011, 03:46 PM   #8
    Default Re: newbe
    Informed decisions are good decisions. The boats come in 3 trim levels. The base version, the "Z" package (power seat/hatch/defroster & numerous other options) and the "LTD" version (solid color gel coat, buckskin color interior). Note though that the base version is still a very well equipped boat!
    The boat will likely run in the high 40's to maybe touching the mid 50's depending on the model.
    Old 08-04-2011, 05:03 PM   #9
    Send jbkkic:
    Default Re: newbe
    Thanks I called the owner today the boat has power seats and motor cover. Cap call exhaust that does not work properly.(have to manually open or close) I am trying to get over out-patient surgery and hope it does not sell until I can look at it. If I buy the boat I will be back in touch. Thanks again
    Old 08-04-2011, 05:37 PM   #10
    Default Re: newbe
    Best of luck with the recovery and with the boat!
    Newbe question - 260Z JNLeChevet Original Mariah Talk 3 12-10-2008 09:02 PM
    There are 397 users
