Bilge Pump Problems
Introductions
Old 07-05-2011, 07:47 PM   #1
BigMark Clark is currently offline
My Year: 2007
My Model: sx18
Send BigMark Clark:
Default Bilge Pump Problems
Just becam a member and need some assistance on a bilge pump problem. I have a 2007 sx18 and the automatic bilge is not working at all but the bilge blower will run when turned on manually. Here is the strange part. The bilge blower does not remove any water even when I know there is water near the engine. I dont know the difference between the automatic pump and the bilge blower. Does anyone know how to replace the automatic bilge blower and what part number it might be? Thanks for the help.
  • Old 07-05-2011, 08:03 PM   #2
    Bill's Avatar
    Bill is currently offline
    My Model: Z222
    My Engine: 496 HO Bravo lll
    Send Bill:
    Default Re: Bilge Pump Problems
    Hi BigMark Clark
    the bilge pump is the pump that sucks the water out of the Bilge and the Blower is to suck out the gas fumes from the engine compartment It should be turned on and run for several minuites before you start the motor and during idle(slow) speed check the float on the bottom of the bilge pump this pump will be under the engine somewhere mounted to the bottom of the boat The float may be stuck. Hope this helps
    Bill
    2001 Z222
    Old 07-05-2011, 08:18 PM   #3
    You mean you haven't been using the bilge blower before starting the boat up??? If you haven't you have seriously been risking your boat and everything in it going 'boom'!
    Old 07-05-2011, 10:07 PM   #4
    My Year: 2007
    My Model: sx18
    Send BigMark Clark:
    Thanks for the reply guys. I wll for sure use the blower before starting now and will check to see if the float is stuck.
    bilge , sx18
    Bilge Pump ROMFORD_NAVY Sea Fox - Mariah Talk 2 06-03-2011 01:22 PM
    Bilge pump question nglauer Original Mariah Talk 7 07-27-2010 01:44 AM
    Bilge pump issue adornare Original Mariah Talk 12 03-29-2010 03:30 AM
    Bilge pump andyc Sea Fox - Mariah Talk 7 07-14-2009 04:01 PM
    bilge pump John Miller Original Mariah Talk 7 05-18-2009 07:25 PM
    There are 401 users
