Temp gauge removal.
Introductions
Old 10-11-2022, 12:08 AM   #1
Wingnut71 is currently offline
My Year: 2005
My Model: SX21
My Engine: 5.0 Mercury
Send Wingnut71:
Default Temp gauge removal.
Hello. anybody have some advice as to the best way to remove the temp gauge or any gauge for that matter.I currently have a 2005 sx21.
My mechanic has traced back the issue to the temp. gauge being faulty. Thanks for any advice.
  • Old 10-11-2022, 01:02 PM   #2
    GregT is currently offline
    My Model: Z275ST
    Gallery Images: 7
    Send GregT:
    Default Re: Temp gauge removal.
    Usually it is simply a U-bracket bolted to the back of the gauge that holds it in the dash. remove the nut and bracket and pull the gauge out the front. The part I don't know is how to get to the back of the dash on your model boat. Maybe someone with your model will help out here.
    Old 10-13-2022, 01:00 AM   #3
    I think the Sea Fox built boats allowed access thru the seat back cushion in the bow area like the original Mariahs did. Failing that you probably have to remove the kick panel under the drivers console and access it from below. Neither are fun.
    Old 10-13-2022, 11:48 PM   #4
    My Year: 2005
    My Model: SX21
    Send Wingnut71:
    Yes.Thanks for the tips.I have laid on my back under the console.it doesn't look like easy access.
    Gauge Removal - 03 SX9 Zoomnbyu General Maintenance 6 07-18-2020 06:40 PM
    Wanted: air temp/sea temp gauge mikec Mariah Parts For Sale & Wanted 0 06-01-2010 12:21 PM
    Fuel Gauge Removal? spinks99 Projects 2 04-16-2010 02:22 AM
    Jumpy temp gauge imwalton Original Mariah Talk 3 08-03-2009 01:11 PM
    Temp gauge rooperdan Boating 101 2 05-24-2009 09:23 AM
    There are 387 users
