Temp gauge
Boating 101
Old 05-24-2009, 12:33 AM   #1
rooperdan's Avatar
rooperdan is currently offline
My Model: 1998 SHABAH 210
My Engine: Built 350 Alpha Drive
Gallery Images: 10
Send rooperdan:
Default Temp gauge
Hey every one, I have a question...
We went out on the river this AM and had a great day sking , While running back home I took on some debri at the outdrive and temp shot up to 220 +/-, shut the engine down right away to let it cool down. Every thing seemed ok after removing the weeds from the outdrive but temp gauge only shows 110 and usally shows 175 after runnning for a time. Does anyone think there is asensor that could have gone bad during the high temp period? Or any other suggestions?
Thanks all!
  • Old 05-24-2009, 12:38 AM   #2
    dudders's Avatar
    dudders is currently offline
    My Year: 2006
    My Model: SX18
    My Engine: V6 4.3L
    Gallery Images: 53
    Send dudders:
    Default Re: Temp gauge
    I would take the thermostat off and check it. You may have injested some stuff into the motor and got some stuck there.
    Mind you, it could be something else.
    Just my 2c worth mate.
    Good Luck
    Old 05-24-2009, 09:23 AM   #3
    Hi rooperdan,
    I recommend you check your temperature sender on the motor too.
    Temp gauge: Is this normal, or worrisome? abillmann Boating 101 2 05-22-2009 04:36 PM
    Water Temp markkearns General Maintenance 11 04-27-2009 07:17 PM
    Water Temp and Air Temp Panel brettk Original Mariah Talk 4 02-20-2009 09:20 PM
    water temp clockwood Original Mariah Talk 2 01-21-2009 04:05 PM
    New owner with some problems n(throttle,temp gauge,etc) jasfiveo Original Mariah Talk 2 05-20-2008 02:46 PM
    There are 302 users
