1998 jubilee 244
Introductions
Old 10-25-2020, 12:45 PM   #1
Pullingjake is currently offline
My Model: Z244 DB
My Engine: 5.7 Bravo III
Send Pullingjake:
Default 1998 jubilee 244
Hello all. I have a 98 Jubilee 244 with a carbed 5.7 and a Bravo 3 out drive. I am having a simple yet complicated issue. I bought this boat early 2020. Used it all summer. Great boat. Issue is it has a severe starboard lean only under power. I have to load everyone on the port side when cruising. I am only 195. When I am the only one in the boat it is down right dangerous. The boat sets perfectly level when no one is in it. Two batteries in the back port side. Nothing other than life jackets stored in the boat. I have 22 pitch props. This is where my question lies. This boat has an unbelievable amount of torque and will only run about 32 mph before it is turning way to hard. Could this be torque lean due to this prop setup has the big front prop and small rear prop. Front turns left rear turns right. Seems I need a 26 or so. Any help would be greatly appreciated.
  • Old 10-25-2020, 02:37 PM   #2
    Hudson River Steve's Avatar
    My Model: Z280
    My Engine: 7.4L MPI Bravo3
    Send Hudson River Steve:
    Default Re: 1998 jubilee 244
    There are many possibilities that would explain a list underway. The whole idea behind dual counter rotating props is that they cancel out the tendency to torque the boat to one side. Are either of the props damaged? Does your boat have trim tabs or Smart tabs? Are they operating or set correctly? How about the hull, does the starboard aft have a hook in it from sitting on the trailer?
    Hudson River Steve
    1999 Z280
    7.4 MPI, Bravo3
    Old 10-25-2020, 03:20 PM   #3
    My Model: Z244 DB
    Send Pullingjake:
    Thanks for the reply. There are no tabs on the back of the boat. The hull theory is a possibility. I'm looking in the engine bay right now and the front of the engine is pointed slightly to the port side. It's noticeable to the eye. Doesn't explain the right side lean but it definitely is a cause for concern. Props are stainless steel and in good shape.
    Old 10-25-2020, 04:18 PM   #4
    Trim tabs (whether Smart Tabs or hydraulics/electric) will help with the lean but determining the cause is needed.
    1998 244 Jubilee Mustang 1944 Introductions 1 09-30-2020 01:32 AM
    Member Boat For Sale: 1998 240 Jubilee RMBIGDOG Mariah Boats For Sale & Wanted 0 04-05-2017 04:03 PM
    1998 Jubilee 214 Blenderbill Original Mariah Talk 9 05-16-2013 10:30 PM
    Wanted: 1998 204 Jubilee bigdoggone Mariah Parts For Sale & Wanted 5 07-07-2009 01:42 AM
    Jubilee 214 1998 rulin5150 Introductions 4 10-11-2008 10:53 PM
    There are 359 users
