MX19 Docking and Courtesy Lights
Old 08-12-2013, 06:38 PM   #1
foolmoo is currently offline
My Model: MX19
My Engine: Mercruiser Alpha ??
Send foolmoo:
Default MX19 Docking and Courtesy Lights
I have a '91 MX19 that is running well. I'm trying to fix up a couple of minor items. Currently, trying to get the docking lights and courtesy lights working. I suspect a fuse, as none of those lights power on and the courtesy light switch on the console does not light up when engaged. Suspect either a bad switch or a blown fuse.
Does anyone have any suggestions about how to attack this problem? Many thanks in advance!
Greg
  • Old 08-12-2013, 08:09 PM   #2
    Default Re: MX19 Docking and Courtesy Lights
    Electrical can be a bugger Greg.
    Check your fuses on both sides with a meter.(or at least a test light)
    Check power at switch and out of switch
    Just keep working down the line with your meter/ test light.
    A big issue on boats are grounding problems. Check and clean any ground you can find.
    Also check your bulb sockets also.
    Just a few common things to check.
    foolmoo (08-12-2013)
    Old 08-12-2013, 08:19 PM   #3
    My Model: MX19
    Send foolmoo:
    Is the fuse panel located behind the drivers' kick panel?
    Old 08-12-2013, 08:22 PM   #4
    Look up under the dash above the steering wheel next to the starboard side of the boat.
    console switch , courtesy lights , docking lights , fuses
    Replacement Courtesy Lights WetWilly Original Mariah Talk 27 05-24-2020 07:24 PM
    LED Docking lights for your Mariah mikeyt General Maintenance 16 06-18-2010 11:31 PM
    Courtesy lights out waynehooper General Maintenance 1 07-15-2008 06:36 PM
    Courtesy Lights plokhoyc Sea Fox - Mariah Talk 7 07-15-2008 02:49 AM
    Wanted: Interior Courtesy Lights? bdbyrnes Mariah Parts For Sale & Wanted 2 10-17-2007 09:48 PM
    There are 300 users
