Engine warning alarm
Introductions
Old 08-13-2017, 07:58 PM   #1
mrbillstl is currently offline
My Model: Davanti
My Engine: 7.4 Bravo one
Send mrbillstl:
Default Engine warning alarm
Does anyone know the location of the engine warning alarm on a 1995 Mariah Davanti 7.2L. That noisy little booger quit working this weekend. I removed the access panel behind the instrument cluster from inside the cuddy. I know it somewhere in that location. Thanks! MrBill
pllevine likes this.
  • Old 08-14-2017, 01:53 AM   #2
    TCJ95Z-235 is currently offline
    My Model: Z235 Davanti
    My Engine: 7.4L Bravo1 Corsa
    Send TCJ95Z-235:
    Default Re: Engine warning alarm
    Mr. Bill,
    I have a 95 Z-235 Davanti 7.4L Carbureted. The alarm sounder on mine is located behind the access panel you mentioned near the back of the Speedo & Tach. Black plastic about the size of a .50 cent piece. If I get over to the boat this week I'll send you a pic..
    Thank you TCJ95Z-235 for this useful post!
    mrbillstl (08-14-2017)
    Old 08-14-2017, 03:36 PM   #3
    My Model: Davanti
    Send mrbillstl:
    Great info!! I'll check it out.
    Thanks!!
    Bill
    Old 08-14-2017, 04:17 PM   #4
    My Model: Davanti
    Send mrbillstl:
    Found it!! It was laying loose and our of sight under the tach. I knew it had a purple feed wire so I started wiggling every purple wire that wasn't attached to something.
    Thanks again!!!!!!
    MrBill
    TCJ95Z-235 likes this.
    Old 08-14-2017, 05:06 PM   #5
    Send TCJ95Z-235:
    Mr. Bill,
    You're welcome. Glad you found it.
    I ordered my Mariah in May of 95, took delivery in July of 95 and hopefully will have another 23 years on the pond with it.
    If I can help you with anything else send up a flare
    engine alarm? muzzleflash120mm Original Mariah Talk 2 11-14-2016 03:12 PM
    Engine Alarm Problem Doc Mercury MerCruiser 8 09-05-2014 06:41 PM
    warning alarm only beeps twice. Brad Mercury MerCruiser 4 04-24-2011 03:07 AM
    Warning Alarm Beeping Every 4 seconds ShabahZ280 Mercury MerCruiser 8 11-05-2008 03:35 PM
    7.4L MPI Engine Warning Alarm ShabahZ280 Mercury MerCruiser 13 02-09-2008 07:39 PM
    There are 397 users
