audio warning system
Introductions
Old 03-21-2016, 01:33 PM   #1
mszola is currently offline
My Year: 2003
My Model: SX8
My Engine: 3.0
Send mszola:
Default audio warning system
I just recently purchased a 2003 SX8 with the 3.0L engine. I've been told that the boat should have an audio warning system that alerts you of low fluid levels. I also was informed that this warning should sound when you turn the key to the on position. I do not hear anything when i turn the key on, and I am just trying to confirm that this model does come equipped with this feature.
  • Old 03-21-2016, 02:35 PM   #2
    Default Re: audio warning system
    Assuming Mercruiser Alpha outdrive and possibly quicksilver 3000 shifter... Yes it should make a beep when battery is on and ignition is turned on prior to starting. It is possible the little speaker is disconnected intentionally or accidentally or it is broken.
    It warns to high temp, low outdrive fluid and oil pressure. See HERE
    Old 03-22-2016, 01:52 AM   #3
    My Model: Z258
    My Engine: 7.4 & Bravo 3
    Send 99 Mariah 258:
    My 99 Z258 7.4 Mpi Bravo 3 sometimes will give the 3 beeps at ignition on and sometimes won't. I always hear the fuel pump come on though. It did work twice when I had a drive oil leak and once when my temp rose from a bad raw water pump impeller.
    Mercruiser Warning System & Beep Codes mikeyt Mercury MerCruiser 0 05-16-2013 02:37 AM
    z212 electrical, lighting,audio caraudio91 Original Mariah Talk 2 06-22-2012 11:43 AM
    i need some help on audio with speakers and amp jdecoudres Sea Fox - Mariah Talk 3 03-03-2011 04:09 AM
    2001 shabah engine audio alarm John Steffy Original Mariah Talk 2 05-13-2010 08:58 PM
    Audio jdecoudres Chit Chat/Off-Topic 10 01-25-2010 06:00 PM
    There are 375 users
