2001 shabah engine audio alarm
Old 05-06-2010, 10:32 PM   #1
John Steffy is currently offline
Send John Steffy:
Default 2001 shabah engine audio alarm
This will be the second season that we have owned this boat which we have really enjoyed except,beginning the middle of last summer, the audio engine alarm has been going off while underway. Just now and then at the beginning to almost constantly now. We have checked everything that we can think of including unplugging the sensor at the power steering pump. All fluid levels are fine and all gauges are reading in the correct range. It's starting to drive us nuts. Has anyone else had this problem ?
  • Old 05-11-2010, 05:48 PM   #2
    Default Re: 2001 shabah engine audio alarm
    Hi John, I wasn't aware that there was a alarm sensor on the power steering pump. I thought the alarm system consisted of the oil pressure, water temp and outdrive oil lever sensors. The few times the alarm issues were posted on the club, most suggested that the outdrive oil level sensor seem to be the culprit so I recommend you check that first, it's the easiest to check sine it's just a float switch.
    Good luck,
    Bgiltnan likes this.
    Thank you WetWilly for this useful post!
    John Steffy (05-11-2010)
    Old 05-13-2010, 08:58 PM   #3
    Yep, I second the outdrive oil sensor. That was the culprit with my alarm system constantly going off. I had to replace the sensor and reservoir, $46 in parts.
    John Steffy (05-13-2010)
    Audio jdecoudres Chit Chat/Off-Topic 10 01-25-2010 06:00 PM
    2001 Shabah 222 HIN Tag Rowdyh55 Introductions 5 05-01-2009 03:18 AM
    7.4L MPI Engine Warning Alarm ShabahZ280 Mercury MerCruiser 13 02-09-2008 07:39 PM
    There are 279 users
