1993 Mariah MX20C
Introductions
Old 05-16-2015, 01:44 AM   #1
JAG Thread Starter
JAG is currently offline
My Model: MX 20C
My Engine: 4.3 L Alpha one
Send JAG:
Default 1993 Mariah MX20C
Hi to all!
I am a new guy to the club. I have an overheating alarm problem with my 4.3L Alpha One engine. I have checked as follows:
Both water pumps OK
Risers and flappers OK
Thermostat seems OK
I hope someone can help me troubleshoot the overheating or electrical problem? Could I have a problem with the temperature sensors? Are they located below the thermostat? Please help!
JAG
  • Old 07-05-2015, 08:00 PM   #2
    Jester is currently offline
    My Model: MX20
    My Engine: 5.7L Merc Crusier
    Send Jester:
    Default Re: 1993 Mariah MX20C
    If all else fails, it could be the impeller is worn and not drawing enough water into the engine. It’ has happened to me, replaced the impeller and not problem since.
    You did not mention what year it is. It may be the original impeller .
    Does it have a heat indictor?
    Another thing to check is your fluid level for the out drive.
    Some of the reservoirs have a float with an alarm.
    If the fluid id low the alarm will go off.
    Old 07-06-2015, 02:20 AM   #3
    You should buy a service manual or become a contributing member here at this site to gain access to those manuals.
    Here's a link to the alarm codes: Mercruiser Warning System & Beep Codes
    1993 Mariah tclip Original Mariah Talk 12 08-26-2013 01:30 AM
    1992 Mariah MX20C bnova Mariah Boats For Sale & Wanted 0 02-22-2012 03:07 AM
    1993 Mariah TBSR72 Introductions 0 06-08-2009 04:36 PM
    New owner 18 ft Mariah 1993 pull Introductions 1 01-17-2009 10:41 PM
    There are 250 users
