bravo 3 hose?
General Maintenance
Old 06-15-2014, 08:09 PM   #1
samimarkie is currently offline
Status: In Limbo
My Model: MARIAH 24' DECK BOAT
My Engine: 5.7L INBOARD
Send samimarkie:
Default bravo 3 hose?
Might anyone know what this hose is on the bravi 3 setup? It's on a 2000 Mariah jubilee 24 ,ft deck boat?
  • Old 06-16-2014, 04:09 PM   #2
    Default Re: bravo 3 hose?
    Exhaust bellows
    Old 06-16-2014, 05:11 PM   #3
    Status: In Limbo
    Send samimarkie:
    Thanks. That is what I assumed. Does it really matter much if they are cracked open? any harm caused by it?
    Old 06-16-2014, 05:29 PM   #4
    Won't hurt a darn thing.
    Play all summer and replace this fall when you do drive service.
    Old 06-16-2014, 09:59 PM   #5
    Something to consider: if the exhaust bellow is that bad off the others may not be far behind. That's one heck of a way to end a weekend and/or boating season.
    Old 06-17-2014, 12:47 AM   #6
    I wouldn't get too worried about the exhaust bellows. I know guys who remove them & run without them. Personally i would do what Larry suggested. When you winterize the boat this fall, that's a good time to replace the bellows. And while you have the drive off, check the drive bellows closely for cracks or splitting. At Moto says, that's a far more serious issue. And heck, while you have the drive off, if your trim/tilt gauge isn't working and the sensor needs replacing that's a great time to do that job too cuz the wiring has to be run thru the outdrive/bellows.
    Red 210 LE 7.4 Bravo 1 rayzorback Mariah Boats For Sale & Wanted 8 07-06-2013 12:27 PM
    Bravo III for Bravo I Motoxxx43 Original Mariah Talk 6 05-01-2013 04:48 PM
    running with a water hose/ear muffs midwest mariah Original Mariah Talk 17 06-13-2011 02:44 PM
    Cooling hose replacement Jbetschart Original Mariah Talk 1 11-02-2010 11:54 PM
    water issue when hot? certain hose? duketter Mercury MerCruiser 1 06-01-2010 09:23 PM
    There are 297 users
