Need some screwing advice.
General Maintenance
Old 01-16-2014, 07:02 PM   #1
TomFasig is currently offline
My Model: 201 Talari
My Engine: 5.7L Alpha One Gen II
Send TomFasig:
Default Need some screwing advice.
Does anyone have any recommendations on how to repair the hinges that hinge the back seat in a Talari 201? The screws have come loose and someone has put larger screws in their place, but they have loosened, also. I would like to repair this somehow, so that it looks right. I don't just want to move the position of the hinge, because that would leave an ugly spot in the carpet on both the floor and the seat. I can't get to the under side, to put nuts on the screws. Any advice will be greatly appreciated.
Tom Fasig
1996 Mariah Talari 201
5.7L Mercruiser Alpha One Gen II
  • Old 01-16-2014, 08:44 PM   #2
    Andy b's Avatar
    Andy b is currently offline
    My Model: Diablo 180
    Gallery Images: 9
    Send Andy b:
    Default Re: Need some screwing advice.
    Pull back the carpet.
    Drill out the holes a bit.
    Fill the holes with some fibreglass resin, then when hard pilot drill and re-fix the screws
    The Following 2 Users Say Thank You to Andy b For This Useful Post:
    ColoradoDiablo (01-16-2014), mikeyt (01-16-2014)
    Old 01-17-2014, 12:16 AM   #3
    I've done the same with Gorilla Glue. The screws will break before they come out though. Good an bad I suppose
    Oregondunes likes this.
    Old 02-01-2014, 11:16 PM   #4
    gahooligan's Avatar
    My Model: 202
    My Engine: 5.7l
    Send gahooligan:
    how do you keep the resin in the hole? I need to fix a few on mine as well. I thought about using well nuts... I good non permanent (see gorilla glue above...) solution is best.
    Old 02-02-2014, 10:26 AM   #5
    Andy b's Avatar
    Gallery Images: 9
    Send Andy b:
    If you can get under the hole then just plain old duck tape will do the job. if not the try stuffing the hole with a roll of paper. push it into the hole deep enough to give you a good depth to fill.
    (be prepared to do some swearing each time you push it too far! )
    When I did a couple of my snaps that had come lose, I put masking tape over the top and bottom of the hole. I then used a counter sink bit through the top tape to open up the hole to a cone shape. this way the hole and the tape were the same size if you see what I mean...
    Filled the hole and then removed the masking tape, No mess
    As for the products you mentioned? sorry but I have no knowledge of them
    Advice Clive Introductions 1 09-29-2010 10:25 PM
    need advice bdydrpranger95 Original Mariah Talk 7 08-04-2010 10:55 PM
    Need Advice Mariah Z202 Boating 101 3 07-16-2009 01:12 AM
    Advice brucedennis1 Original Mariah Talk 2 04-02-2009 10:33 PM
    Need Advice Please Sheli Sea Fox - Mariah Talk 6 07-23-2007 01:43 AM
    There are 217 users
