Alarm when key in accessory position
General Maintenance
Old 07-12-2013, 10:34 PM   #11
nglauer's Avatar
nglauer is currently offline
My Model: 180 Diablo
My Engine: 3.0L Alpha one
Send nglauer:
Default Re: Alarm when key in accessory position
My 2001 Diablo with the 3.0L operates like a car as well. Movement is clockwise as follows OFF-ACC-ON. I believe mine is all original, as the key has the correct cut/letter code. Also, mine came with the stock radio and unmodified wiring - it was setup to either turn on the radio via the accessory switch (no key) or ignition switch (with key). Again, my wiring was never cut or spliced. If it was modified someone took the time to run the wires inside the master loom. No other items ran on the accessory until I added my lowrance lst-3800. Also, mine has never beeped or let out any type of alarm noise since I purchased it. I'm not even sure where the noise maker is located.... unless it played through the original radio which I replaced before every taking it on the water.
Nick
Sent from my SCH-I535 using Tapatalk 4 Beta
Nick
SOLD 8/5/2013 -2001 Mariah Diablo 180 3.0L Alpha 1
-2007 GMC Canyon 4x4 Crew Cab
-2010 GMC Acadia SLT
-1993 Camaro "SCCA Project Car"
  • Old 07-16-2013, 03:16 PM   #12
    kriswd40 is currently offline
    My Model: Diablo
    My Engine: 4.3 Mercury
    Send kriswd40:
    The alarm horn usually comes on as the system is energized just before you start the boat and it should go off once you have started it up. That is normal and if you have a 3 position switch (off-on-run) then it should trigger in the 'on' position. I'm a little surprised at your ignition not turning counter-clockwise (mine does) but possibly someone else here has a similar setup and can comment or as Andy suggested, someone may have already replaced the ignition cylinder. Do u still use an original Mariah key with the logo?
    The only keys I have appear to be copies of keys, so I don't really know if it's original or not. It definately only turns to the right (off, accessory / alarm, run).
    Old 07-16-2013, 03:18 PM   #13
    My Model: Diablo
    Send kriswd40:
    Accessory switch? What / where is that?
    Mine sounds like yours, except there is a loud alarm whenever in the ACC position.
    I don't know what the original radio was, I replaced a tape deck with a CD player when I bought it but I was able to reuse the existing wiring. The tape deck had the same issues.
    What are the Accessory Switches For? Z280Bob Original Mariah Talk 7 07-04-2015 03:37 AM
    The Official "What's the coolest Mariah Accessory that you will never use?? Paul F Original Mariah Talk 21 11-25-2011 12:04 AM
    Stern drive position while trailering? pincourtmariah Trailering and Tow Vehicles 8 07-31-2010 10:09 PM
    noob question re: trailering position m&mmariah Boating 101 3 07-27-2010 04:04 PM
    Key stuck in start position Holy Crap Billyclub Original Mariah Talk 2 07-27-2009 04:10 PM
    There are 338 users
