Re: hello new owner of 03 mariah sx19
I actually didn't know it wasent winterized until I got it home. Then a couple weeks later I found the block cracked and the 2 missing frost plugs. It wasent registed in Mn until me. The last owner had it registered in Wyoming.
That's probably why the last owner let the bank have it.
Not to be pushy , but what did you end up giving for the boat? As said it sucks , but your probably better off to bite the bullet and fix her if you don't have a lot vested in it. Short block is around 1750.00 maybe , long block 2200.00. And if you can do the work..........
It pretty much boils down to how much you like the boat. I got more money in my Diablo than I do in my truck!! JMO |
I paid 9000 for the boat. Bought a lot of stuff for it probably spent another 2000 on parts. Long block is 2200. Total for motor is around 3000. Its a decent boat needs trailer brake work and some cheap interior work.
In my opinion , your really close to what it is worth. But , if you like her I think in the long run you would be happy when it's all over and your on the water.
Again , this is my opinion , I got approx 6000.00+ invested in my Diablo and still going:yes_grin:(paid 3500.00 for her) |
I hope so I like its going to have a 350 now. Just bought a k&n flame arrestor for it. It should fly now. Should go around 60 now with a 4 as prop. Maybe will put a new edelbrock carb on. We will see hope I have better luck after this experience.
Keep us up to date on the progress.
And don't forget , we are all here to help as much as possible:) |
Will do. Do u know anything about disc surge brakes.
Just like your car.
Hydraulic master cylinder with piston controlled calipers. What's the symptoms? |
Master cylinder holds fluid. But I know I don't have brakes. Was going to do pads and rotors. Pads still have a little life left.
| All times are GMT. The time now is 04:39 AM. |
