spark plug help
General Maintenance
Old 04-11-2013, 12:53 AM   #11
Default Re: spark plug help
Husker has the chart! I was contemplating google for that one!
Compression test would not hurt but like you said, 100 hrs is not much. Unless there is a problem waiting to be found.
Personally, Id put in the plugs and see how she ran. Id check each one after a run around the lake and go from there.
Make sure you have fresh fuel too...
  • Old 04-11-2013, 03:34 PM   #12
    Juskol18 is currently offline
    My Model: 202 shabah
    My Engine: 5.7 alpha one
    Send Juskol18:
    ok thanks for yalls help. i will check all tht, get the new spark plugs back in and let you all know how it goes..
    Old 04-12-2013, 01:22 AM   #13
    Send Juskol18:
    i finally got all the spark plugs changed and the rear spark plugs on either side were the same way as described!! what could be the deal?how can i post pics?
    Old 04-12-2013, 02:08 AM   #14
    Only the rear or all 8?
    Old 04-12-2013, 03:11 AM   #15
    Almost sounds like water intrusion to me. Do a pressure test on the cooling system.
    Old 04-12-2013, 03:35 AM   #16
    Posting pics is quite simple. When you are replying to another post make sure you select "Advanced" and then enter your response. Once done & before you hit submit, scroll down the page a bit til you see "Manage Attachments" & click on it. The hit the button that says "choose file", select what file you want to upload from your computer and then hit upload. Once its done uploading the file then simply close the attachments window and hit submit on your reply.
    Z202 oil and spark plug help Andy-Z202 Shabah Mercury MerCruiser 1 06-17-2011 11:19 PM
    spark plug help again aquaknot Mercury MerCruiser 4 09-12-2010 12:12 PM
    spark plugs aquaknot Original Mariah Talk 3 08-17-2010 07:57 PM
    Spark plug MMarko Original Mariah Talk 1 03-16-2009 02:13 PM
    Which Spark Plugs? boarder1010 General Maintenance 2 07-22-2008 03:23 AM
    There are 387 users
