Metal Rescue
General Maintenance
Old 10-04-2012, 08:38 PM   #1
csterner's Avatar
csterner is currently offline
My Model: Z275ST Shabah
My Engine: 6.2L Bravo III
Gallery Images: 9
Send csterner:
Default Metal Rescue
Has anyone used this product before? As some of you know, my boat was born and raised in saltwater until I bought it. The prior owners weren't the most religious at flushing after each use(and yes, I knew this going in...but I got a great deal on it because of that). Anyways, I took off my thermostat housing yesterday and noticed alot of rust and was going to chunk down the $300 for a new one when I found out about soaking it in Metal Rescue and removing all the rust. I then thought..."why can't I run this thru my whole cooling system and clean everything?" It will not damage the seals, gaskets, or rubber, and it is not an acid system. It is water based and I believe has active particles that attack and eat the rust.
So what are your thoughts? I have talked to the manufacturer and they said it would be fine. I would need to rig up some device to capture the liquid coming out of the outdrive to recycle it back thru the cooling system again.
2001 Shabah Z275 ST
6.2L Merc with Bravo III
  • Old 10-04-2012, 09:25 PM   #2
    Oregondunes's Avatar
    My Model: Z302 Bow Rider
    My Engine: 7.4 bravo3
    Gallery Images: 36
    Send Oregondunes:
    Default Re: Metal Rescue
    what if you did like I do for winterization ?
    I bought a cheap 5 gal fuel jug at Home Depot. Clamped on a piece of 8' clear hose from Home Depot with a hose end on the other end that I attach to my ear muffs.
    I set the fuel jug up on the swim step
    I run the motor on the hose til the thermostat opens, then quickly change over to the anitfreeze til it all drains from the fuel jug but I can still see it in the hose.
    Then youd let the solution sit for say (24-48 hours....or longer) then hook up the hose again and flush it out.
    2000 Z302 Bow Rider
    Old 10-04-2012, 10:49 PM   #3
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    Hey Oregon!
    That is a good idea. But when you turn the engine off, does the cooling system stay pretty full or does most drain out after you shut it off? I would want the system to stay full to stay in contact with the solution. That is why I was thinking to just let it run continuously. But I think I like your idea better!
    2001 Shabah Z275 ST
    Old 10-05-2012, 02:58 AM   #4
    Gallery Images: 36
    Send Oregondunes:
    the other option would be the trash can method. fill it with you solution, drop your outdrive into it and just let er run. tho eventually it's gonna get warm.
    tho you could shut it down, let it cool down say over night, then fire it back up tomorrow.
    2000 Z302 Bow Rider
    Old 10-05-2012, 03:10 AM   #5
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    That would be a good idea except that my water intake is not thru my outdrive. I have a pick up under the engine. Also I can't lower my outdrive into a trash can cause it sits too low in my trailer and I can't ever completly lower my outdrive on the trailer. So I think I might try your original idea and see what happens.
    2001 Shabah Z275 ST
    Old 10-05-2012, 04:23 AM   #6
    Gallery Images: 36
    Send Oregondunes:
    without a lower water pick up in the outdrive, how do you flush your cooling system ?
    2000 Z302 Bow Rider
    Old 10-05-2012, 01:32 PM   #7
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    Fake-a-lake instead of muffs.
    That's how the wakeboard guys do it anyway.
    Old 10-05-2012, 01:51 PM   #8
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    I have a raw water pickup on the bottom of my hull that feeds the water pump. I installed a "T" valve right next to my raw water pickup valve in the engine room. I have a quick release fitting and just snap my garden hose on and close the pickup valve and turn the water on.
    2001 Shabah Z275 ST
    Old 10-05-2012, 01:59 PM   #9
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    With the Bravo III, the factory had 2 options for raw water cooling; you can either bring raw cooling water thru the outdrive intakes and into the water pump, or thru a seawater pickup located on the bottom of the hull right under the engine.
    I personally like the pickup because it is much higher in the water than the outdrive ports, and where I boat there is a lot of sand and shallow water and just less chance of clogging up those ports.
    I cannot use the under hull "fake a lake." Boat sits too low on the trailer. So I just installed the T and it works great.
    2001 Shabah Z275 ST
    Old 10-05-2012, 02:08 PM   #10
    Gallery Images: 36
    Send Oregondunes:
    love the fake a lake idea tho
    2000 Z302 Bow Rider
    Metal switch panel Steve91T Original Mariah Talk 13 05-04-2012 02:59 PM
    Any Issue With Welding Metal Attached to a Mariah? Slash9point5 Original Mariah Talk 0 08-09-2011 07:52 PM
    Trim-Metal Wiring Plate christoll Mercury MerCruiser 3 04-08-2010 04:35 AM
    There are 267 users
