Metal switch panel
Old 05-02-2012, 02:45 AM   #1
Steve91T is currently offline
My Model: Z202
My Engine: 5.7 Alpha 1
Send Steve91T:
Default Metal switch panel
I thought I'd show you guys my little project.
This is the problem.
Not only does it look bad, but it doesn't even hold the CD player anymore. So, I decided to make another one out of metal.
This isn't ideal but I think it'll work. I really don't know what happened here because the rest of the interior is in beautiful shape. Must just be the poor design and the weight of the CD player.
My plan was to just trace out the old panel onto the sheet metal which means everything has to come off. I have never seen so many wires for 3 switches.
Now, I am the most unorganized guy in the world and I have no doubt that there would be no chance that I'd get it all back together correctly.
Fortunately, my wife actually enjoys this kind of thing. I sat back and drank a beer while she labeled wires.
After that, the water/air temp gages has to come off.
BTW, that tan square sticking up is the temp adjustment. Pretty easy to get to.
Don't loose these.
I just taped the pieces down and traced it out. Yes, I'm showing off my folding workbench a little
Then grab a beer and your favorite tin snips and go to town.
And here's my stopping point for the night. I used my angle grinder and cut out the CD box. I'm not going to add the CD holder, so that'll just be a good place for a decal or something.
One thing I'm not sure about is what to use to cut out the switch holes. Angle grinder is too big. Maybe a jig saw with a metal blade?
When it's all cut out, I'm going going paint it with a hammered finish black paint. I think it'll look nice.
Finished product tomorrow!
TexasZ212 likes this.
  • Old 05-02-2012, 04:40 AM   #2
    Zackattack's Avatar
    Send Zackattack:
    Default Re: Metal switch panel
    Looks good so far! Nice job.
    Zack
    1994 Z212 Shabah
    Old 05-02-2012, 12:09 PM   #3
    One of our other members did a very similar project a while back and now sells those panels on ebay. I do like the fact though that you've given us a bit of a 'How To'....
    Old 05-03-2012, 03:22 AM   #4
    Brewfixer's Avatar
    My Model: Z222
    My Engine: 5.7
    Send Brewfixer:
    Dang! I hate looking at other folks projects because now I want to do mine... I did these back in my car stereo installation days. I would use 3/8 - 1/2" Lexan (plexiglass) backed by aluminum plate. Basically after you shape the lexan, you would peel the paper off one side only and paint it (usually black) and install with painted side against the aluminum plate. Once you peel the paper off the non painted side you would have a rich deep glossy black finish that you could reach into. It was kind of fun.
    Now I want to do mine since I am seeing signs of stress cracks from the radio and I dont need the CD holder anymore (who listens to CD's anyway?).
    Well way to go. Cant wait to see the finished product.
    2001 Mariah Shabah Z222
    Old 05-03-2012, 03:37 AM   #5
    My Model: Z202
    Send Steve91T:
    All done! It took me all freaking day! Mostly because I was using a dremel and an angle grinder. Had I had the right tools, it would have gone much faster, like a water jet I was so afraid of making a mistake and having to start over, so I really took my time.
    Here she is! Brew, next time that is what I'm going to do! That would look so much better than a painted piece of metal, but for $10, I can't complain. Tomorrow I'm going to make a simple bracket to attach from the middle of the panel to the rear of the CD player to help support it.
    JB weld some screws for the water/air temp.
    Painted with a black glossy hammered finish.
    Can you guess what the small switch is? If you guessed for blue LED underwater lights, you were right! Those will be installed on Monday. I've got family coming into town this weekend, otherwise I'd do it tomorrow.
    Overall I'm very happy with the panel, although I can't help but to stare at my mistakes. The big one is the rectangle for the water/air temp display. I had no good way to make a perfect rectangle. That's something that's going to bug me, but I'm sure someday I'll redo it with lexan like brew suggested.
    Now that I have that open space where the CD holder used to be, it looks like it's missing something. Any suggestions?
    Old 05-03-2012, 03:52 AM   #6
    Brewfixer's Avatar
    My Model: Z222
    My Engine: 5.7
    Send Brewfixer:
    Try an "EJECT" Switch...(family coming over right?)
    But really she looks good. The nice part is that you can overlay Lexan right over that and use the plate you made to support everything as you intended. Lexan is really easy to work with even if you only have a left handed crescent wrench...
    Old 05-03-2012, 04:23 AM   #7
    DCB_MINDED's Avatar
    My Model: Shabah 238
    My Engine: 5.7 Alpha1
    Send DCB_MINDED:
    If you move the switches around some, you might be able to make room for a nice GPS/Fishfinder in there
    '99 Mariah Shabah 238
    5.7 Thunderbolt w/Alpha1
    Old 05-03-2012, 04:39 AM   #8
    Zackattack's Avatar
    Send Zackattack:
    Looks like an iPod nano might fit there.
    I mounted an open pocket there for storing STUFF. And then mounted an iPhone/iPod on the lower left open area. It plugs in easy that way.
    Looks great! Nice work
    Zack
    1994 Z212 Shabah
    Old 05-03-2012, 07:35 PM   #9
    My Model: Z202
    Send Steve91T:
    All done! I made a quick metal bracket to help support the rear of the CD player. It works great, really solid.
    Old 05-04-2012, 01:22 AM   #10
    My Model: Z202
    Send Steve91T:
    You know what I think would looks good? A white "Mariah" sticker. Where can I get one?
    Actually, what I really want is to have someone with a water jet cut out "Mariah" in cursive and then I'd back light it with blue LED's, but that's not happening.
    Fuse Panel ezgoin45 Original Mariah Talk 6 07-30-2019 03:02 PM
    Any Issue With Welding Metal Attached to a Mariah? Slash9point5 Original Mariah Talk 0 08-09-2011 07:52 PM
    Have you seen this new Switch panel? recelect Chit Chat/Off-Topic 4 12-14-2010 04:33 AM
    Trim-Metal Wiring Plate christoll Mercury MerCruiser 3 04-08-2010 04:35 AM
    Wanted: Glove Box Panel snobordin8 Mariah Parts For Sale & Wanted 2 12-16-2009 05:05 PM
    There are 323 users
