Question Concerning General Maintenance
General Maintenance
Old 09-17-2012, 03:44 AM   #1
mariahsx20 is currently offline
My Year: 2006
My Model: SX20
My Engine: 5.0L MPI
Send mariahsx20:
Default Question Concerning General Maintenance
I bought my Mariah this summer. I had a mechanic check out the engine and stern drive. No visual or running issues found. The engine is a 2006 Merc 5.0L MPI w/Alpha 1 Sterndrive w/200 hours when purchased. Bought it from a private seller and I am the 3rd owner. It has run great all summer. I was calling around to found a place to winterize it and to find a mechanic I could trust. All of them have different levels of service that will be perform. Of course they push me for the most expensive. Since I have no maintanence records on the the boat. One Mechanic said you should pull the stern drive every three years to check the shaft, bearing, and alginment. Since I have no experience with I/O drive, I am wan ing to know if that is something that you typically do, I concern if they pull it off they will cause issues down the road, or is that something is routine. Also, since the boat new to me I was going to get the Oil change, Fuel Filter and Gear Lube replace. Any other recommendations would be greatly appericated.
Thanks in advance
Steve
  • Old 09-17-2012, 12:08 PM   #2
    Default Re: Question Concerning General Maintenance
    If u are not sure of the maintenance history of the engine/outdrive then having the mechanic pull the outdrive & check or grease the gimbal bearing is probably a good idea. I plan on doing mine every 4-5 yrs. The other thing that likely should be replaced is the water impeller in the outdrive. They should be replaced every 4-5 yrs also.
    Maintenance Reminder USN Mariah owner Mercury MerCruiser 2 09-08-2010 11:36 PM
    Electrical switch maintenance Phlorida General Maintenance 1 06-27-2010 05:07 AM
    2 Windshield Maintenance questions shoot001 General Maintenance 2 03-10-2009 09:31 PM
    Owner Performed Maintenance, who does it Rick of Austin Original Mariah Talk 4 08-08-2008 12:23 PM
    There are 322 users
