Electrical switch maintenance
General Maintenance
Old 06-26-2010, 10:43 PM   #1
Phlorida is currently offline
My Model: 250 Sundancer
My Engine: 5.7L Bravo II
Send Phlorida:
Default Electrical switch maintenance
Today I swapped out the broken OEM marine stereo and replaced it with a new Kenwood with an iPod dock. In my initial attempt I discovered that I was only getting five volts so I pulled the switch panel on the dash, cleaned up the leads on the stereo switch and immediately got back to twelve volts. All of the other switches show similar levels of corrosion on them but I left them alone for now.
A question for a project that I won't even consider doing until it cools off this fall - is there anything I can coat/spray on the leads to slow the corrosion process down?
  • Old 06-27-2010, 05:07 AM   #2
    jgreen's Avatar
    jgreen is currently offline
    Gallery Images: 2
    Send jgreen:
    Default Re: Electrical switch maintenance
    I dab on a little dielectric grease after the contacts are clean and tight. Keeps water away.
    Jay
    Electrical issue! Who's the electrical guy? Eddie Original Mariah Talk 9 05-06-2009 04:52 AM
    Maintenance on a 2001 Bravo 3 outdrive greencanuck Original Mariah Talk 0 05-01-2009 07:57 PM
    2 Windshield Maintenance questions shoot001 General Maintenance 2 03-10-2009 09:31 PM
    Owner Performed Maintenance, who does it Rick of Austin Original Mariah Talk 4 08-08-2008 12:23 PM
    There are 322 users
