New badges for the back of seats install ?
General Maintenance
Old 12-20-2011, 02:11 PM   #1
csterner's Avatar
csterner is currently offline
My Model: Z275ST Shabah
My Engine: 6.2L Bravo III
Gallery Images: 9
Send csterner:
Default New badges for the back of seats install ?
I am going to be replacing the badges on the seat and wondering what is the easiest way to do it? Also, I will probably replace the badges on the side of the hull as well. Any insight into the easiest way to do this would be greatly appreciated!
2001 Shabah Z275 ST
6.2L Merc with Bravo III
  • Old 12-20-2011, 04:29 PM   #2
    Default Re: New badges for the back of seats install ?
    It's pretty easy.
    1. Peel off old shields. You can use a hair dryer for heat if need be.
    2. Remove all of the old adhesive using alcohol, vinyl off, or goo gone.
    3. Clean surface using acetone to remove any wax or contaminants
    4. Peel off paper backing of new shields.
    5. Apply, and press down firmly.
    I'd suggest doing this in warm weather as it makes things much easier. Also, make sure you get the Gold shields.
    Old 12-20-2011, 07:49 PM   #3
    csterner's Avatar
    Gallery Images: 9
    Send csterner:
    Originally Posted by ShabahZ250 View Post
    It's pretty easy.
    Finally something easy to do!
    2001 Shabah Z275 ST
    Old 12-20-2011, 08:16 PM   #4
    theeasynine's Avatar
    My Model: z240 Talari
    Send theeasynine:
    I replaced mine on the hull. It makes a world of difference.
    Patrick
    How do you fold down back to back seats??? scubydo Original Mariah Talk 9 05-22-2024 02:17 AM
    Tower Install jnd_v Original Mariah Talk 3 06-10-2011 08:49 PM
    back to back to bench dontalari94 Original Mariah Talk 5 02-26-2011 01:19 AM
    mariah stiching on back of seats are now brown lcoen777 General Maintenance 4 06-04-2009 05:06 PM
    Almost done with A/V Install! Z275 Original Mariah Talk 4 04-14-2008 07:46 PM
    There are 302 users
