How do you fold down back to back seats???
Old 10-23-2010, 02:43 AM   #1
scubydo is currently offline
My Model: 200
Send scubydo:
Default How do you fold down back to back seats???
I've tried everything I can think of to fold down the back to back seats, but they wont lay flat. I wonder if the Previous owner did something when he had them re upholstered. There is a handle on the front side that lets them slide forward and backwards, but they wont lay down????
Thanks for any help.
  • Old 10-23-2010, 03:02 AM   #2
    Default Re: How do you fold down back to back seats???
    When all else fails, read the Owners manual. If i remember right, the instructions for the back to back seats are on page 101.
    Be forewarned though, age and lack of use make them very stiff to open. Once you do, take the time to lubricate the hinges underneath.
    Old 10-25-2010, 07:54 PM   #3
    Dredd's Avatar
    Dredd is currently offline
    My Model: MX-19 - Sold
    Send Dredd:
    It "takes some practice," iirc.
    Really though, once you do get them open take a look in there so you can understand how they work.. that helps quite a bit.
    Old 11-15-2010, 02:48 AM   #4
    DKM187 is currently offline
    My Model: Z202
    My Engine: 5.7L EFI
    Gallery Images: 2
    Send DKM187:
    There are two tabs on the top of the rails inside the seat frames that are holding the two seats back to back. Its a little awkward to reach up from the side to release. They can also be released from raising the bottom cushion of either seat. On my seats I made a cable that attaches to the end of the tab and runs up to the top of the seat back, now I just pull up on the two cables (with rings on the end to hold on to) and the seats release and lay flat. Hope this is helpful. Once you lift up the bottom cushion and take a peek inside you'll see exactly how the tab on one seat latches over a allen-head on the other seat.
    Jason
    Old 11-18-2010, 01:57 AM   #5
    nglauer's Avatar
    nglauer is currently offline
    My Model: 180 Diablo
    My Engine: 3.0L Alpha one
    Send nglauer:
    If it makes you feel any better I haven't completely figured mine out. I noticed the track bolts had backed out some from the wood.. allowing some play on mine as well. I tightened them up and lubricated everything. Once I figured out how to lay them down... hooking them back up was the difficult part. I have one side where the tab grabs, the other side... not so much. Mine acts as if the seat backs are to thick... or the tabs are not long enough. I haven't taken it apart to inspect... but I figure it's an easy fix once I put some time into it. Good luck, Nick
    Old 11-18-2010, 03:41 AM   #6
    My Model: 200
    Send scubydo:
    I played with mine today. Still can't get them to lay flat. I'm just worried about putting too much muscle into it out of fear of breaking something. I guess I'm just going to go for it.
    Old 11-18-2010, 01:42 PM   #7
    nglauer's Avatar
    Send nglauer:
    Can you see anything with a flashlight? could one of the tabs still be holding (one of mine never releases without a fight). Could the previous owner have placed something under the seat that is now stuck?
    Good luck.. keep us posted. I rarely put mine down because they are a pain in the @ss... and a pain to get them latched back. However, I bought mine off the original owner.. and he told me they folded them down once, and that was at the dealership during a demonstration. They never used it, or the top... it was still wrapped up.
    Nick
    Old 11-18-2010, 04:51 PM   #8
    Dredd's Avatar
    Send Dredd:
    The PO on my boat didn't even know they laid flat.
    OK, here's a crude drawing of how it works.
    The straps with the ramps on the ends are hooked over the red nipples. The straps are attached to the seat.
    The gray things in the drawing are just the tracks for the straps.
    So, you have to rock the seat up high enough to get the straps unhooked.
    Also, on mine the nipples are towards the stern on the port side, and towards the bow on the starbird side. In other words, it's all mirrored. I'm not sure if they're all this way or not but it sure does make it easier when you remember which is which direction.
    Hope my Crayola drawing is of some help.
    Old 11-21-2010, 04:23 AM   #9
    wcso909 is currently offline
    My Model: Shabah
    Send wcso909:
    When all else fails, read the manual. If i remember right, the instructions for the back to back seats are on page 101.
    MikeyT, Which manual are you referencing here? Are you talking about the owner's manuals posted on here?
    Thanks in advance
    Old 05-22-2024, 02:17 AM   #10
    Float is currently offline
    My Model: Tamari 190
    My Engine: 4.3 L. Alpha 1
    Send Float:
    I just figured out how to lay them flat on my 1994 Talari 190. Lift up the front edge of the front facing seat, this will unhook the locking pins on both sides and the seat folds flat. Good luck
    GregT likes this.
    Back on the Water!!!! MAJIC Original Mariah Talk 2 05-25-2010 04:12 PM
    Back again ... 180diablo Chit Chat/Off-Topic 14 12-08-2009 07:16 PM
    Happy to be back jchemotti Original Mariah Talk 2 10-19-2009 04:36 AM
    mariah stiching on back of seats are now brown lcoen777 General Maintenance 4 06-04-2009 05:06 PM
    I'm back MariahMan Chit Chat/Off-Topic 6 12-28-2007 02:51 PM
    There are 251 users
