z210 engine cover wood rot
General Maintenance
Old 07-25-2011, 02:32 AM   #1
ual777mech's Avatar
ual777mech is currently offline
My Model: z210
My Engine: 7.4 bravo III
Send ual777mech:
Default z210 engine cover wood rot
Hello
Has anyone repaired there engine cover hatch the hinges pulled out of the rotted wood in the back and can anyone tell me how hard it is to replace the wood?
do you remove the plastic cover on the bottom side of hatch then peelm back the upholstery?
thanks
  • Old 07-25-2011, 02:56 AM   #2
    darkcalling's Avatar
    My Model: Z278 Limited
    My Engine: 502 Bravo III
    Gallery Images: 3
    Send darkcalling:
    Default Re: z210 engine cover wood rot
    Didn't have the plastic on my other boat but I did remove the gas shock mounts pulled off the upholstery. Then I just bought same thickness of pressure treated plywood and stained it with water seal 4x replaced the upholstery. Had it for 10 years after never another problem. Good luck.
    darkcalling
    Z 278 Limited
    Old 07-25-2011, 11:24 AM   #3
    ual777mech's Avatar
    My Model: z210
    Send ual777mech:
    thanks
    Power engine cover/hatch NogginDoc Boating 101 1 07-19-2010 07:17 PM
    Sun Deck / Engine Cover Acadianbasic Original Mariah Talk 6 06-01-2008 01:14 PM
    check out this engine cover 180diablo Chit Chat/Off-Topic 17 04-04-2008 08:43 PM
    Problem w/ power engine cover joe2106 Original Mariah Talk 6 12-28-2007 04:12 PM
    Power ram for engine cover 97 Z222 Original Mariah Talk 2 11-12-2007 09:56 PM
    There are 377 users
